Kitchen Appliances - Others Logo
Posted on Jan 29, 2010
Sanyo 5-cup Micom rice cooker, no power
Our Sanyo 5-cup Micom rice cooker doesn't work any more. No response to Menu button and Start button, as if there is no power. Clock related buttons still work. I want to repair it, but cannot open the bottom...
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
713
Points
5
I had the exact same problem with my rice cooker. I took the lid apart. There was a broken wire because of the constant friction of the hinge when open and close the lid. After I soldered it, it started to work again.
  • 1 more comment
  • Anonymous Dec 11, 2011
    Thank you so much !
    I was able to fix it with a little effort.
    To open the rid was a heck.
    But not too bud.saved me about a hundred dollars!
  • Anonymous Apr 15, 2012
    Thank you for posting the solution. We experienced the exact problem and was able to fix it following your recommendation.
  • Anonymous Jul 29, 2012
    thanks for posting this. I was scratching my hair trying to figure out what could be the problem. Very close to ordering a new rice cooker for a replacement
How do i find a user guide for my sanyo rice cooker ECJ-18F
Dear anonymous
you have probably found it by now, if not try this site:
http://manuals.com/
All the best,
Kolbrun
Sanyo ECJ-D100S Micom 10-Cup Rice Cooker stop working. Just use couple hours ago before it stop working. It is 5, 6 years old, looks like there's no power, only clock. All buttons do not response...
I have the same problem today. I'm lucky to find this thread and fix the problem. The cooker have two broken wires. The good news is that one wire is black and the other is yellow. If both were yellow, I might have to figure out which one connects to which.
Thank you all for the questions and answers,
Liyan
37helpful
3answers
Can I buy only inner pot that Sanyo ECJ-D100S 10-cup rice cooker?
Amazon offers pretty large number of inner pots. Go here Amazon com inner pot and pick of them (which one fits). feel free to ask sellers anything.
I hope this was helpful.
Enjoy
1helpful
Hello, I have a Sanyo ECJ 18F Micom Rice Cooker, and today when it was cooking vegetablaes rice the display desappear, only appears half a seven, I unplugg and now on the display doesn´t appear...
Hello I had a similar problem with that same cooker, there is a power IC with readings AC05E that controls the screen and the power of the rice cooker. Get a replacement of that ic and you are good to go.
1helpful
I need a cooking instrutions guide
good day,
hope this link below will solve your problem.
cooking
try amazon.com
Not working
Firstly check fuse in the plug if no avail Then could be element or thermal trip/ check if has customer reset cut out.....Please leave feedback
1helpful
Rice cooker keep feature turns rice crispy
This sounds like the thermostat inside the unit has went out and is overheating whitch in turn is cooking your rice too fast and too hot! if the thermostat is replaced it will cook the rice even again!
Please rate my response to your question
Thank You!
2helpful
2answers
Toshiba fuzzy logic rice cooker repair
I am new to the rice cooker scene, but, I'll bet that I know exactly what's wrong with your cooker.
Are you handy with a screwdriver?
Can you open it up?
If so, I might be able to talk you through fixin' it!!!
Top Sanyo Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Sanyo Kitchen Appliances - Other Expert? Answer questions, earn points and help others
