Question about Pentax K1000 35mm SLR Camera
Pentex k1000 rewind knob unscrewed, shaft fell inside camera
My Pentex k1000 rewind knob unscrewed and the shaft that it screws onto has fallen inside my camera. how do i get it out without damaging the camera if i cant open the back the way i normally would?
Posted by redhot364 on
  • Anonymous Mar 25, 2014
    AHH so the rewind shaft fell out of my brothers camera and i cannot put it back in!!! Help me!! the back of the camera is open already i just cant put the shaft back in it place HELP ME ASAP PLEASE
Anonymous
    Scholar:
  • 185 Answers
First make a small hook on the end of a straightened paper clip. insert the hook and pull up rotating the hook as you pull up. being careful not to bend the spring near the hole. once the back door is opened check the rewind shaft, there should be a beveled edge on the collar of the shaft. rotate the shaft while pushing up. if no beveled edge on the shaft use the paper clip to push the spring out of the way while inserting the shaft. if it still will not return file a bevel on the collar of the shaft. I am assuming there is no film in the camera as the canister will prevent the shaft from falling in.
Posted on Jan 31, 2010
Anonymous
    New Friend:
On my pentax k1000
the black fuzz looking stuff which is on the top of the inside when u take off the lens,is falling off a lil n getting inside where the mirrors are.
would i need to get it repair ?? would it mess up the pictures in anyway if i dont get it repaired?
thank you somuch
Posted on Mar 02, 2010
How do you replace the rewind shaft of a pentax k1000 without causing any damage?
Open the camera film cover back.
Stick a flat blade screwdriver between the silver film sprocket, then turn the Film Rewind Crank out.
[email protected]
Jun 25, 2014 | Photography
The flip up switch to rewind the film has fallen off, I have all the original pieces but cannot fit the bar in. How do I take off the rewind lever to fix it?
Perhaps the following site will help you visualize the fixing. I remind you that these film cameras sell for very little now days and can be purchased for a song. see: http://www.slideshare.net/lokerd/pentax-k1000-35mm-slr
Apr 14, 2011 | Pentax K1000 35mm SLR Camera
My pentax k1000 works great except for when I first load the film. Every time I first load the film, the rewind knob wont rotate when I snap pictures. Everything on the inside is intact and usually I have...
I'm not sure I see a problem here. There is enough slack in the film that the first few exposures can spool out of the canister without it turning. If in doubt, close the back and then _lightly_ turn the rewind crank to take up the slack. Don't force it, just turn it until you feel resistance. Then advance the film and see whether the rewind knob turns.
Feb 28, 2011 | Pentax K1000 35mm SLR Camera
Removing Nikon FM2N top plate
Unscrew the rewind knob and remove a circlip under it (You may need to grind the tips of a pair of round-nose pliers for this). Remove the disk and pull the rewind shaft stop off the hub (a spring and flat plate). Remove the two screws. You'll need a special tool to remove the little stud the shaft stop was pivoting on. Take a 1/8 inch screwdriver and grind a slot in the blade. Use this tool to remove the stud, then remove the three screws from the plastic cover ring.
Do not remove the center screw from the shutter speed dial. Remove three screws from the side of the dial and pull off the grip ring.
Jul 08, 2010 | Nikon Photography
The nob that rewinds the film fell off my camera, and i unfortunately could not find it. Is there anyway to get the film out of the camera before I get a replacement piece?
yes, after dark find the darkest room or closet you can find, make sure no light is coming in around the door. pull up on the rewind shaft to open the back door. remove the film and rewind it into the canister by hand. turning to the right.
Oct 21, 2009 | Pentax K1000 35mm SLR Camera
I have a pentex k1000 camera with a tamron ae 28-80 and ae70-210mm lens. They have pentex mounts on them. Are these lenses adaptable to todays autofocus cameras like the canon eos or pentex k100
If it is a pentax lens then yes but only for pentax cameras...it wont fit a canon at least not to my knolege. pentax makes all there cameas with the same lens mount.
Jun 07, 2009 | Tamron AF 28-80mm Lens
Pentax K1000 rewinding knob restore
Pentax fan
There is a spring in the way. straighten a paper clip and from the top of the camera push it out of the way while you gently push the shaft up. rotating the shaft helps.
or you could file a little of the shaft collar on an angle ( if it's not there ) then rotate the shaft while gently pushing up. don't bend the spring.
Mar 21, 2009 | Pentax Photography
How do I rewind and take the film out of a pentax k1000?
mhamabrown,
push the rewind button on bottom of camera and turn rewind knob to the right, ( clock wise ) then pull the rewind knob up to open the film door.
Feb 24, 2009 | Pentax K1000 35mm SLR Camera
Rewind shaft installation
bremerfamily,
to remove the shaft, lift the knob until the film door opens, place a small screwdriver between the prongs and turn the knob to the left. pull the shaft down and out. replace the shaft------ if the new shaft has a notch on the collar just rotate the shaft while pushing back in. if no collar, use a pin to push the spring away while inserting the shaft----- don't force it or you will bend the spring.
Dec 22, 2008 | Pentax K1000 35mm SLR Camera
Purchase part
If the threads are not stripped on the knob or shaft, just screw it on clock-wise.
If the threads are stripped on the shaft, it must be replaced, same with knob.
To replace the shaft (if the knob is off) just pull it down in the film compartment. now there is a spring to hold the shaft up or down if the new shaft has a beveled shoulder just turn the shaft while pushing it back up. If no beveled shoulder is on the shaft then with a long needle or pin hold the spring back while pushing the shaft back up. Don't bend the spring. just move it out of the way.
Aug 18, 2008 | Pentax K1000 35mm SLR Camera
Pentax K1000 35mm SLR Camera Logo
Top Pentax Photography Experts
Vernon Taylor
Are you a Pentax Photography Expert? Answer questions, earn points and help others
