Usb 1.0 or usb 2,flatbed scanner compatability
Please can you help.?Is my maxdata3150x laptop usb 1.1 or usb 2.?also can I connect a flatbed scanner to it,Many thanks,Frank Levaul-grimwood
Anonymous
    Brigadier General:
  • 10,406 Answers
Find a USB device, such as a memory-stick, that is "USB 2.0" and connect it to a USB port. If Windows XP pops-up a window ("this device will perform better when connected to a USB 2.0 port"), then you have connected it to a USB 1.1 port.
Yes, you can connect a scanner, if it has a USB connection. Not all laptops have a parallel-port ("old-style" printer) port, but some scanners require a parallel-port.
Posted on Jan 29, 2010
Testimonial: "Thanks ikkenom,Really grateful for your help.I am a real novice so really appreciate someone troubling to help.All the best,bigears6"
Can't find scanner
Is the scanner visible in Device Manager? If not you have a hardware or connection issue.
Is the connection USB or network? If network have you checked TCP/IP settings? If USB are the USB items OK in Device manager?
Is it an old scanner connected to a new Windows version such as Win7. Some old scanners are not compatible.
Jan 11, 2014 | Microtek ScanMaker 9800XL Flatbed Scanner
Connector question
dear,
well to rectify this problem you have 2 options:
1. either you can purchase a PCMCIA card with 50 pin Scsi connector.
2.or USB to SCSI convertor.
all this kind of connectors and convertor are available in IT shops
Regards
May 15, 2008 | Agfa DuoScan T1200 Flatbed Scanner
Trying to connect to an HP Scanjet 4570c to a Dell Inspiron 1750 notebook computer. When I connected the USB cable, it said it updated some drivers, but there is no icon on the laptop to scan, and when I...
If you are under Windows 7 , it's because HP doesn't produce anymore drivers for your unit beyond VISTA .
Download the latest driver available from here : http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=77368&
and try running your scanner with it . If you don't succeed , try in compatibility mode .
If it still doesn't work please don't blame me , blame HP .
Best regards .
Feb 01, 2011 | HP 4570C Flatbed Scanner
Fujitsu fi-5750c Flatbed Scanner need to
The back panel of the scanner should have a USB connection to the right of the SCSI ID selection switch (the farthest right on the back). Just get from any source a standard male/male A/B USB cable.
Then get the correct drivers here: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/twain/v921720c.html . Additional software may be found here: http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/drivers-downloads_index.html
I hope this helps.
Apr 30, 2010 | Fujitsu fi-5750C Flatbed Scanner
Cable connectivity with my laptop through a "parallel to usb cable". My laptop has no parallel port but only usb ports.
make sure you follow this step :
1. install driver USB to Paralel port (LPT1) before the cable connected to PC
2. After the driver installed, install the cable - and it supposed to be detected
3. the last think u have to do is install the scanner/printer driver
if it is not work, i guess the problem is on the USB to paralel adapter, or the driver not installed correctly
Jun 01, 2009 | Acer ScanPrisa 640P Flatbed Scanner
Cannot detect scanner
There is going to be issues with connecting it in this fashion. The usb adapters are not addressed the same as a real parallel port. This means that the drivers probably do not have a chance at working. The other issue is usb ports on laptops rarely have the power to drive devices larger than a mouse or keyboard. This means that the usb adaptor may not have enough power to function. Try plugging it into a powered usb hub then to the laptop. This may give it enough power to do what you want if the drivers are compatible of course.
Good Luck.
If all else fails goto goodwill and get a usb scanner. I always see stacks of them. Most are the usb type.
Feb 20, 2009 | Canon CanoScan N340P Flatbed Scanner
MEM48U Flatbed scanner
My done the same way, but it just stop working one day after doing a windows download. At that time they was a download that work fine and it is still working, I forgot what web site I went to, but it was a Memorex site.
Hope this helps.
Sep 12, 2006 | Memorex MEM48U Flatbed Scanner
Computers & Internet Logo
k24674
