Pentax Optio Z10 Digital Camera Logo
Question about Pentax Optio Z10 Digital Camera
What is pentax optio z10 reset button
Posted by sameer_6731 on
Glyn Kendall
  • 146 Answers
The reset is on the settings menu, it does not have a reset button.
To get to the settings menu press the menu button then press the right button on the controller to get to the setting menu.
When you are on the setting menu you need to go down using the down arrow on the controller to the 3rd page were the reset option is.
Press right to access the reset options then select Reset then ok.
Posted on Jan 31, 2010
Anonymous
    New Friend:
How to unlocked card on a pentax optio z10 digital camera
Posted on Apr 30, 2010
2helpful
The sd card in my optio z10 says it's locked. How do I unlock it?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Me kids have played with my camera and set the green mode.if i push the menu button it tells me that the green mode needs to be canceled touse this function
You may need to look up how to reset your camera to factory settings. Look that up in the manual. You will not loose any pictures.
Hope this helps.
Optio Z10 is stuck on green mode, how do i fix it?
Go into the menu and find "reset"...follow the on-screen instructions.
How to format memory card pentax optimo z10
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
1helpful
Pentax Z10 won't turn on.
Press and hold the playback button for 2 seconds. The camera should turn on and be in playback mode. Switch to Camera Mode by opening the from slider cover. Hope that fixes it. See Pentax Z10 Manual Page 34.
http://www.pentaximaging.com/files/manual/OptioZ10.pdf
Cheers Jon. Sydney Australia.
Can't install software for Pentax OptioZ10
If software is a problem why not just buy a USB to SD card adapter, and plug your SD card directly into macbook - about $10
I have a pentax optio z10. when i turn it on (slide the front open) it says "green mode" then proceeds to turn blank..
i got the same problem. try holding the play button and turning on. it wont help fully, but i was able to look at my already takin pics
Top Pentax Cameras Experts
David Shaub
Marvin
Marvin
W.L.
Are you a Pentax Camera Expert? Answer questions, earn points and help others
