Question about E-Machines eMachines T3830 PC Desktop
My emachine T2958 will not turn on but it did work for about 3 weeks and one day it just quit working. I opened it up and plugged it in and a green light came on and is making a buzzing noise. Is it the power supply or something to do with the mother board.
Posted by callie_post on
Jose Velazquez
  • 229 Answers
It sounds like a power supply failure. Do you plug it straight into the walll or into a surge protector. If you are close to a best buy, go to geek squad they will diagnose the issue for free but the fix is real simple. Let's just put it this way there are a few things that protect the motherboard from getting fried. If it is the PSU u are looking at roughly 40-60 dollars and it is a matter of 6 connections. Give me a shout if you need more help
Posted on Jan 29, 2010
I have an emachines t2958. Somehow the administrator log in was deleted completely. I cannot get onto my computer with any administrator privileges. I've tried rebooting and the restore disc. Nothing...
Use another PC and Search for "Administrator password reset" to download a reset tool. You'll have to write this to a bootable CD. My favourite such tool is a utility call AnyPassKey.
Dec 21, 2013 | E-Machines (T2958) PC Desktop
I need to reboot my emachines T2958 lost CD.
You will have to call E machines and buy one - sadly
Apr 21, 2010 | E-Machines (T2958) PC Desktop
I need to reboot e machined620 triedf10 but then got stuck
T2958- Emachines is very much like I have.
If you are running Windows Vista. I can advise you now to open the machine and blow out the dust.
Remove the ram and reinstall checking for tightness. Check all wires and make sure the fan is working.
Now with the side still off - turn on the machine and make sure you have all of the fans working.
If the machine still refuses to boot. Try booting it and also tap the F8 key. Tap the key every other second until it boots into the safe mode.
Once in safe mode run your anti virus and any fixes you can then reboot.
This should do it for you and if not.
Please consider reinstalling windows or - insert the install disk and then do a system repair.
Mar 26, 2010 | E-Machines (T2958) PC Desktop
I want to to return my emachine to factory settings..Have the T2958 ver 1.1 restore dvd. Won't auto run- I click on the icon and its just text. Is that a command prompt?
you will need to restart the computer and boot off the restore dvd.
This is done outside of the operating system.
When computer is first turned on keep hitting f10 untill you get the boot menu up, choose the dvd drive and it should work for you.
Mar 11, 2010 | E-Machines (T2958) PC Desktop
I have a T2958 and toof the face off. Can you
eMachines doesn't give out this kind of info, and I don't have one in the shop.
eMachines also had the habit, of using a few different manufacturer's of motherboards. Intel, TriGem, MSI, Asus,and FIC to name five.
Plus eMachines would use whatever was available at THAT moment, when they were producing that particular model line. (Not stating the T2958 specifically. Whatever model line they were making at the time)
Plus at the time the T2958 was made, Gateway had bought out eMachines. (eMachines later bought themselves back)
However all is not lost here. At the time the T2958 was made the motherboards were manufactured by Intel.
The Intel D845GVSR
Uses the Intel D845GV MCH, and the Intel ICH4 southbridge chipset
(MCH. Memory Controller Hub. Intel's naming for their Northbridge chipset)
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T2958
You are looking to see where the wires go, on the Front Panel header of the motherboard, from the Front Panel of your computer.
(Front Panel header on a motherboard, is essentially where the wires go that come from the Front Panel of the computer. When referring to a connector on a motherboard, a connector is a Header.
The Power On switch wires, HDD Activity Lamp, Reset switch, {If used}, and Power On Lamp, are located in the Front Panel, for your computer)
{Front Panel = 'Face'}
As stated, eMachines does not give out this info.
I just need your patience, and your eyes. I need you to compare a photo of a motherboard to yours.
When you open your computer case, the side cover should come off of the Left side.
The back of the computer will be to the Left, the front to the right.
The Processor will be at the top of the motherboard, and the Ram Memory slots will be to the right.
Observe the motherboard photo at the top of this page,
http://www.dexplor.com/phpBB2/viewtopic.php?f=13&t=7747553&sid=8fa7e78bbadfbd6fde083b28641248cc
Orient in your mind so that the motherboard in the photo will have the Processor to the top, and the Ram Memory slots to the right.
Should you have no idea of what I'm referring to here, please come back, and state so in a Comment.
The Front Panel header is composed of three individual headers, (Connectors) for this motherboard.
J9F2, J9G1, and J8H3
The J9F2 is for the USB ports used in the Front Panel. We won't be concerning ourselves with this header.
J8H3 is located to Right side of the CMOS battery. It has two pins sticking up.
This is where the Power On LED light plugs into, IF, the Power On LED light has Two wires, and the light is one solid color when lit up.
J9G1 is located below the CMOS battery, and is located on the bottom edge of the motherboard.
There are two rows of pins sticking up.
The rows are parallel to the edge of the motherboard.
The top row has 4 pins.
The bottom row next to the edge of the motherboard has 5 pins.
The pins are numbered from the Left, going to the Right. There MAY be a number 1, or 2, stamped on the motherboard.
I wouldn't count on it.
The top row of pins, going from the Left towards the Right are,
2, 4, 6, and 8.
The bottom row of pins going from the Left towards the Right are,
1, 3, 5, 7, and 9
There is no Pin 10.
1) Pins 1 and 3 are for the Harddrive Activity light. (HDD)
2) Pins 2 and 4 are used for a Power On LED also.
3) Pins 6 and 8 are for the Power On switch
Should you have more questions concerning this, please state so in a Comment.
Mar 06, 2010 | E-Machines (T2958) PC Desktop
Emachine T2958, tested power supply (good). Green
Is your PC making any beep sounds, anything at all on monitor? if nothing try removing cpu then re-install cpu?
Feb 09, 2010 | E-Machines (T2958) PC Desktop
I CAN NOT CONNECT TO THE INTERNET ..using Linksy wireless remote
the wireless card installed to your computer is working..as you said you can view all wireless networks...your computer is good too...the only issue is you cant connect to the wireless router...
turn off and unplug the power cable of the Modem
turn off and unplug the power cable the router
wait for 30 seconds
plug in and turn on the modem, wait for all the light turn to solid green ( no blinking lights )
then power on the router
if you saw the wireless icon light turn solid...
go to your computer...right click the wireless icon...select repair
if this doesnt work....reset your internet router by press and hold the reset button behind the router near the power plug (atleast 15 sec)
then connect your PC..the wireless network dont have the WEP key anymore because of the reset..you can reconfigure and put back the WEP key when you get connected.
Mar 16, 2009 | E-Machines (T2958) PC Desktop
EMachine T2958 - No power
You are right about checking PSU first. Check PSU by using a PSU tester. If you don't have a PSU tester you can go to any computer reapir shop and have them check out the PSU for you.In case PSU, is fine there is a possibility that motherboard may be shot.
Nov 05, 2008 | E-Machines eMachines Desktop PC
Emachine T2958 will not turn on - has no power
Dear asksforhelp,
As u have told that u have change the power cord then the second thing u can try that check the SMPS is it working or not to check this u have to know that where is the SMPS where u pluged in the power cord in the cpu that thing is SMPS check wether the SMPS fan moving or not if no then u have to replace the SMPS if it is working then u have check wether the mother Board get the power supply or not check the 12 pin power connector insert it in mother Board if still it not working then it is definatly problem with u r Mother Board. So it is better for u that to go for New One.
Feb 13, 2008 | E-Machines (T2958) PC Desktop
E-Machines eMachines T3830 PC Desktop Logo
179 people viewed this question
Top E-Machines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
