Question about NorStar M7310 Corded Phone
I would like to change the display names that are attached to each line. How do i do this?
Posted by claire_atkin on
george peters
    President:
  • NorStar Master
  • 860 Answers
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
Press the next key (bottom right arrow) .
The display should say Lines.
Press the show key (top right arrow)
The display should ask for a line number
Press the list soft key
The display should say Line001 and the line name. if this is the line name you want to change... Press the show key (top right arrow)
The display should say Name
Press the show key (top right arrow) .
Enter in the new name for the line
Press the next key (bottom right arrow) . If you want to program additional line names press the heading key(top left arrow) till you see "Line 001; new name" and press the next key (bottom right arrow) repeat the procedure for the additional lines
press the Rls key when finished
Posted on Jan 29, 2010
How do I change the display name on KX-T7630
http://service.us.panasonic.com/OPERMANPDF/KXT7630.PDF
May 13, 2014 | Panasonic KX-T7630 Corded Phone
Phone line doesn't ring
First, lets get rid of the static. Try Feature #86. This will turn off background music. When a music source is not attached you get static.
Enter programming by using Feature XXX66344 password 266344. The display should show "Terminals&Sets" press the top right button with an indicator in the display. The display should show "Show set: ____ enter the extension number that you want to check or program. The display will show ***:name. Press the top right button three times. The display will show Show Line:____ with options to Scan or List. If you select Scan it will show the lines assigned to that phone. If you select List it will start with the first line in your phone system showing one of four states 1- Unassigned, 2- Ring Only, 3- Appear&Ring, 4- Appear only. Change the selection on the line by using the CHNG soft button. This is where line assignments are changed from the four states for each extension.
The only other thing that will keep an extension from ringing is "Do Not Disturb" or DND. Feature 85 and #85 will turn this feature on and Off.
Jan 31, 2014 | NorStar Meridian M7310 Phone
Can't change name on phone? the screen that pops up reads "terminals&sets" and I "set" to change a certain line. Show set is displayed. I type in the number that the name needs to...
It sounds like your in the right area, you just need to go a little farther into that sets programming.
when you enter in the persons extension number press the show key (top right arrow)
The display should say LINE ACCESS
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Dec 22, 2010 | NorStar M7324 Telephone
How do I change the name on the phone from the previous employee to the new employee's name?
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change the name on.
Nov 10, 2010 | Nortel Norstar 16-Line PBX Speakerphone
We have employees that have left and new ones have taken their place. How do I change the names on the phone display to the new employee?
The display should now ask for an extension number. Enter extension number you want to change the name on.
press the Chng soft key. (or the clear key to erase)
Jan 21, 2010 | Nortel T7316E 2-Line Corded Phone
How do i change the names that are on the display on a Nortel 7316e
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the name on.
Oct 16, 2009 | Nortel T7316E 2-Line Corded Phone
Trying to change name on a phone - new employee
Sep 30, 2009 | Nortel T7316E 2-Line Corded Phone
How do I change the display name on incoming line
You would have to go into program mode.
program 93-1 would do the trick.
Tony
Ameritel
732.477.7733
Jul 09, 2009 | Toshiba DKT-2020 Corded Phone
Change name on a Nortel M7324
1. Press the Rls button then ** FEATURE 266344 (CONFIG)
2. Password is 23646 (ADMIN) The display reads Terminals & Sets
3. Press SHOW ans enter the Extension for which you want to enter a name.
4. Press SHOW, again
5. Press the NEXT key until the display reads NAMES at the top left corner.
6. The bottom right corner reads CHANGE, press the far right soft key.
7. To move from one letter to the next use the far right and far left soft keys or the # key.
8. When you are finished Press next.
9. Press the HEADING key to get back to TERMINALS & SETS and start again!
Navigation Keys: Line 1 = HEADING Speed Dial = SHOW
Line 2 = BACK Last No. = NEXT
This can only be done from the main handset and only one at a time. The Soft Keys are the three small buttons right bellow the screen.
Jan 28, 2009 | NorStar M7324 Telephone
Winmail to Outlook express 6
Outlook Express does not display any message attachments if TNEF-encoded file (winmail.dat) was received. If you are expecting some attachment, but do not see any, it still can be there.
To decode such a message perform the following steps:
  1. Save the whole e-mail message to an *.EML file via File, Save As, or Drag-and-drop.
  2. Open the *.EML file in a text editor such as Wordpad or Notepad.
  3. Locate the line Content-Type: application/ms-tnef;, and change the Content subtype to something else, such as Content-Type: application/zzz;
  4. Locate the line name="winmail.dat" and change to name="winmail.tnf". You may change the winmail part as well, if desired.
  5. Save the *.EML file from the text editor.
  6. Double click the *.EML file from the Windows File Explorer. This will open the message in a mail window and the TNEF attachment should now be available for saving.
  7. Drag the saved attachment into the Winmail Opener program. Decoded attachments will then be there and can be dragged or opened.
Dec 07, 2007 | Microsoft Office Outlook 2003 for PC
NorStar M7310 Corded Phone Logo
244 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
