Question about BenQ PB6100 Multimedia Projector
Hi there my benq dlp projector is showing white spots on the screen when the screen is black can you help me?
Posted by info2613 on
ABRsvcs
  • 4,234 Answers
This is caused by dust on the lens assembly. If you can remove the lens, clean the surfaces with a lens cloth. That should resolve the problem. It is possible that the there is dust in the optical pathway inside the unit as well. If the cleaning of the lens does not resolve the problem, the unit should be brought in for a professional cleaning. It is not suggested that anyone open up these units as there are fine adjustments that can be changed internally easily that could result in convergence problems.
Dan
Posted on Jan 29, 2010
Anonymous
    New Friend:
I had my benq projector professionally cleaned $70.00 cleared it all up. perfectly.
Danny
Posted on Sep 11, 2010
BenQ MP 670 black spots
Black spots are more likely to indicate a partial failure of the DLP chip. The lamp cannot produce such a symptom sadly.
Repair will be quite expensive...
Mar 27, 2014 | BenQ Office Equipment & Supplies
Vivtek d510 projector has black and white spots covering 1/3 of projected image
The DLP Chip is failing .The DLP or Digital Light Projection Chip contains up to 8 million tiny microscopic mirrors that tilt to project a digital image onto the screen. These mirrors are failing causing light and dark spots to appear.Unfortunately fixing this projector is probably going to cost more than buying a new one. Hope this helps.
Jan 02, 2014 | Vivitek Office Equipment & Supplies
Suddenly, benq mx511 has white pixels showing up....multiplying every day...now the projected image consists of 50% snow.
It probably has the same DLP chip as my Mitsubishi television. The mirrors in the chip set get stuck and create the white spots. There is no way to fix this other than replacing the DLP chip.
Feb 04, 2013 | BenQ MX511 3D Projector
Dust particles being projected onto screen with BENQ MP 525 projector
White spots on the screen are generally caused by a bad DMD chip.Multiple elements of the chip remain continuously on causing these spots.Solution is replacement of DMD chip.
Samr
Jan 14, 2013 | BenQ MP511 Projector
I have a benq MP670 that i bought i China 3 months ago and i live in Kenya... it has white spot al over the place... but there are many in the right side of the screen... what can i do?
Sounds like the DMD chip is getting bad pixel failure. Most likely the chip will have to be replaced.
If the white spots are well defined and rectangular in shape when you get up close to the screen, then this would confirm the problem.
Just tell your friends that it's snowing in Kenya and the snow flakes are getting on the screen and ask the children to try and brush them off. Make the most of it until you can get it fixed, or get another broken one that has a good dmd chip and swap parts.
Sep 20, 2011 | BenQ MP670 3D DLP Projector
White pixels forming on screen and increasing in number. Slight distortion in other spots pixels are extremely bright but small.
This is a problem with the internal DMD chip which needs to be replaced.
Contact BenQ Service,should be covered under warranty.
Samir
Aug 22, 2010 | BenQ MP523 DLP Projector
BenQ PB6100 Multimedia Projector Logo
1,618 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Marvin
Marvin
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
