Question about Panasonic KX-TGA101S Cordless Handset
Incoming calls only ring once then hangs up. Can call out/not in
Incoming calls only ring once then hangs up. I called my home line and the phone rings once then I hear static and the call is lost. I can make outgoing calls but cannot get incoming calls! HELP
Posted by c_payer on
Anonymous
    New Friend:
Reset your mobile
Posted on Jan 29, 2010
Remove the ringing from incoming calls on a norstar. I have multiple extensions in the building but want the incoming calls only to ring to a few extensions
You need administrative rights to get into the PBX. Once in there, you can assign which phones receive incoming calls. It has been years since I worked on the meridian system, so I can't tell you the way to do it, but it is in the manual. It's not complicated. You can also set it up for DAY/NIGHT mode so that in the evening, if required, all phones could ring on incoming calls so that anyone in the building can answer them.
Feb 04, 2015 | NorStar Meridian M7310 Phone
Dell 2135CN cuts-off incoming calls to my home phone number after 2 rings and the call goes to the printer. I hear the ringer inside printer, then hear fax tones, even though the call is not a fax. My...
Hi and welcome to FixYa!
Well if that's the case, the printer should be detached or powered of during call operations. The printer detects incoming calls that's why it triggers it to operate. Turning it off during operation will surely be the solution.
Hope this helps and thank you for using FixYa! Have a good one!
Jan 05, 2011 | Computers & Internet
On incoming calls rings once then stops then person calls again comes thru. also after talking sometime u can hear the system dialing? there are 7 phones in the house one has the FWD light on? could...
The first symptom of an incoming call ringing once then stopping is called trip and ring which is caused by a partial short on the phone line. The second symptom is called crosstalk caused by the two phone lines being shorted to each other. The service provider is most often the cause of these troubles. Often this type of trouble happens during wet weather or shortly after. The third symptom of static on the line cna also be caused by the same conditions. All three symptoms are likely caused by the same trouble from the service provider. Advise you report the trouble to your service provider.
Dec 09, 2010 | Panasonic KX-T7736 Corded Phone (KXT7736)
Incoming calls on home phone ring 1 time and then extreme static
When you unplug everything connected to the phone jack what happens? If it works, you have too many ringers or a short on the line. If it still trips the ring, you have a defective box.
Carl
Jul 06, 2009 | AT&T Lands Phones
Incoming calls briefly ring once then automatically kick over to answering machine. I cannot get any incoming calls
Are you using norstar voicemail system?
If you are and know how to get into the admin programming of it, then you go to the line programming and select the number of rings before the vmail system answers.
set the rings to "3", then the lines should ring 3 times on your phone, then on the 4th ring the vmail system will answer
Jun 26, 2009 | NorStar M7208 Corded Phone
Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Apr 29, 2009 | Uniden DECT 6.0 Cordless Telephone...
Panasonic KX-TG9333T Incoming calls don't go through or ring once and hang up. Sometimes they go through.
I bought a cheap phone, plugged it in and the same thing happened. I called the phone company for line repair service.
Jul 31, 2008 | Lands Phones
Phone keep ringing when incoming call is not picked up (and reach voice mail), and then hang
I need to know more details,
Can you tell me whether you have lotsa messages in your phone?
Jun 28, 2008 | Nokia 1600 Cellular Phone
Can I forward an incoming call to an outside line?
External transfer to Mobile 1. Transfer 2. press 1 and external # 3. Wait for ringing 4. press feature then transfer 5. hang up
Jun 11, 2008 | NEC Electra Elite 32D-1 Corded Phone
Panasonic KX-TGA101S Cordless Handset Logo
4,514 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
