Question about Seagate 500GB Barracuda ES.2 SATA 3Gb/s Internal 500 GB Parallel Hard Drive
New hard drive not recognized on mac pro
I am trying to replace a hard drive a seagate 500gig sata on a mac pro. The startup from disk command is holding down C to boot from cd drive. It doesn't. It defaults to the windows xp partition instead. Bootcamp doesn't help either. What do i need to do since all info is saved on external wd (time machine). I really appreciate any insight to steps needed. thanx
Posted by thissguy on
electronic & computer repair& servicre
  • 12,061 Answers
OK what you could do is connect up that drive to a PC and format it with NTFS, & then put it on the Apple, it should then "See" the drive.Then you can work on it via the Apple.
Posted on Jan 29, 2010
Hi i need to copy files from my macbook to my seagate hard disk which is in ntfs format.. it says it is write protected... help me...
the ntfs format is windows operating system format...
MAC will not recognize this format...
You need to format your hard disk according to the MAC OsX from your MAC computer...
Dec 13, 2010 | Seagate FreeAgent Pro Desktop - 320GB -...
Seagate Barracuda 7200.9 SATA driver problem
If the laptop is also XP, the drive should be recognized without problems. Sometimes this may not happen if the disk is unusually partitioned (could happen if you manually dual-booted it with Linux, for example). Verify the enclosure is working properly and has enough power supplied to, and that it appears in Device Manager. If all this applies, the enclosure must be considered working and the problem might be in the partitioning or disk access.
In XP Pro, do Start > Run Command > DISKMGMT.MSC and press OK. See whether the disk appears (if it doesn't, it's the enclosure, or its drivers - or the disk was dying and is now dead, but that's not very likely), select the NTFS or FAT32 partition - ignore any others - right click and mount the unit as drive, say, G.
If it doesn't work but the partition is found, you may need a more powerful tool such as Paragon Partition Manager.
See also here:
http://support.microsoft.com/?scid=kb%3Ben-us%3B307889&x=12&y=12
Nov 25, 2009 | Seagate 80GB Barracuda 7200.9 SATA s - 8MB...
1st Gen Macbook Pro Hard Drive Clicking
store.westerndigital.com or http://www.seagate.com/www/en-us/products/external/
Nov 08, 2009 | Apple MacBook Pro Laptop Computer with...
Read only on a mac
http://www.seagate.com/staticfiles/support/downloads/firmware http://atulchitnis.net/files/seagate.pdf
Apr 18, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate for Mac
yes you have to mac format it, this deletes all your files. use the disk utility in the utility folder an erase with mac extended
Mar 08, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have had to reinstall my operating system and drives but now the Seagate 500 GB external is not recognized. What now?
Are you using eSATA for the External or USB. If it is eSATA you may need to get the respective drivers for your motherboard for it.
Jan 30, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate free agent go 250 gb external / macbook pro os x tiger
If you can see the drive in Applications --> utilities --> Disk Utility, then you will be able to reformat it in the Mac OS format and read it.
Good day, Damien
Dec 24, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My seagate free Agent exturnal hard drive
Hi, Sorry to hear you are having problems,
When you open your hard drive, is it locked ? Do you see a pencil with a line through it in the bottom left had corner ?
It could be that the drive has inproper permissions....
So, try this, click on the Hard drive icon (Please be sure it is the external drive, NOT YOUR STARTUP DISK ) then get info on the drive. In this info window, at the very bottom, you should see a check box allowing for: ignore ownership on this volume. Please click this box.
Now, try creating folders on the drive...
If this does not work, I highly recommend reformatting this Hard Drive, that is assuming there is no valuable information on it.
After reformatting it, it really should work porperly.
Dec 16, 2008 | Seagate FreeAgent Pro Desktop - 320GB -...
Lost hard disk identification and data systems
Use Recuva and a deep search to see if the files are still on the drive. If so save them to a new location.
Jun 13, 2017 | Seagate 60GB 5400RPM SATA 100 – ST96812AS...
Seagate FreeAgent Desk - "Drive cannot be modified"
I went into Disc Utility and partitioned the whole drive for Mac OSX. After that was done, I was able to write to the drive and copy over files.
Nov 29, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 500GB Barracuda ES.2 SATA 3Gb/s Internal 500 GB Parallel Hard Drive Logo
329 people viewed this question
Top Seagate Computers & Internet Experts
Michael Thomas
Michael Thomas
ChinthakaJ
ChinthakaJ
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
