need to clean the bellow ( rubber around door). theres a tablet you can buy called "Affresh". It will help to remove the moldy smell. just throw it in washer and run through a regular wash cycle. no clothes, just the tablet. If there is a clean cycle on the machine then use that cycle. Whenever you're finished washing, you should leave the door open for about 20-30 minutes so unit can air out. Also you should wipe around the glass and bellow after each use.
Maytag had a big problem with the rubber boot in the front of the washer.They redesigned it to drain better so water would not remain in the bottom and get moldy smelling.Open the door and look down in the boot with a flashlight.Make sure if there are drain holes in the bottom that they are clear and not clogged with soape or lint.Put a couple of old towels in the machine and a little soap and twice as much clorine bleach as normal and run a cycle.It should help.It is also good to leave the door opened between washes if possible.
Try drying your clothes without the dryer sheet and see if the smell is still there. If it is not, then the problem is the dryer sheet. If it is, then you need to describe the smell better. Different people handle smells differently. What smells musty to you may smell fragrant to others. You need to determine if the smell you don't like is really a musty smell, or is it a fragrance you don't like. Have some friends (not family members) smell the clothes and verify if what you are smelling is musty or fragrant.
It could also be that even though the clothes smell OK out of the washer, that the detergent you are using is the cause.
forget the vinegar, theres a product www.affresh.com this will help. you also MUST USE HE( high efficency) DETERGENt. reccomneded amount is 2-3 tablespoons. regular detergent, and too much fabric softener is possibly adding to the moldy/musty smell..
Wash on hottest and longest cycle with regular laundry soap and a bottle of vinegar. After cycle, wash again with soap on hottest/longest cycle. This will clean your washer like new.
Thanks for your suggestion about looking in the lip of the seal. I found one of my three year old granddaughters socks. Also, the seal for very dirty so I mixed a 50% solution and 50% solution of chlorox and used an old towel rag to wipe and wash throughly around the lip seal.
I noted that the aluminum ring inside the washer had also accumulated a lot of dirt. With one hand and fingers I held the wet cholorx towel inside the ring and with the other hand spun the tub around several turns until I had removed all the dirt and grime.
It did have a moldy smell. I'll let you know if this fixed the problem.
I had the same problem, except it wasn't just towels. It was everything. I did some research and found that this is a common problem and nothing a tech can fix. I was about to go out this weekend and spend $1000 on a new washer because I couldn't use this washer on my clothes anymore. I did one more search for a solution and THANK GOODNESS found a solution on another site. A woman had the same problem and, after much trouble, someone at Best Buy finally told her to never use liquid detergent in the machine, not even HE. So I cleaned the inside of my machine, around the door, the rubber seal, etc. I ran the tub clean cycle with bleach and vinegar. The smell was gone and I have been using powder Tide ever since, and the smell hasn't come back!!!!!
I had the same problem. Have you cleaned the filter under the front panel? Simply remove the three screws holding the panel below the door and remove the 2" white screwcap. Be sure to have a basin handy to catch the water. (possibly a couple of gallons if the stainer is really clogged) I suspect you'll find several moldy items that are causing the odor. Good luck.
Shepherd, Finkelman, Miller & Shah, LLC, is currently investigating defects and other problems in certain front-loading washing machines manufactured and/or sold by Whirlpool, Kenmore, and LG Electronics, including Kenmore Elite HE3 front load washers, Whirlpool Duet front load washers and LG Tromm, LG XL and other LG model front load washers, which result in the growth of mold/mildew in the machines and which can cause the staining of clothes and other problems.
On August 29, 2007, SFMS filed a Complaint against Sears Holding Corp. involving its Kenmore HE, HE2, HE3, HE4, HE5 and other front-loading automatic washers. If you own a front-loading washing machine that is manufactured by any of the above-mentioned companies and are experiencing the growth of mold/mildew in the machine, visit the following website: www.frontloadwasherclassaction.com
