Question about Food Mixers
KitchenAid K5sswh mixer after replacing plastic gear-no power
After replacing melted plastic gear, mixer will not power on. Zero power. Could the large black spring loaded magnetic screws on the sides of the mixer be in the in wrong way?
  • Anonymous Feb 25, 2010
    Dear hslincoln,
    RE: There is a new
    Solution for the problem you posted on FixYa
    I want to thank you for
    your very very helpful answer to my question. My son, who is a genius fixed the
    gear, lubricated the mixer but it was dead when he put it back together. He knew
    it had to be something with the large magnetized black screws on each side. When
    I fixed the mixer per your instructions. My son gave me all kinds of praising Kutos. I finally
    confessed that you sent me the link to the diagram that showed exactly what to. It
    was fixed within 3 minutes. Thanks-a-million!
    I want to send a paypal
    payment and give you rave ratings! How do I do that?
    THANKS
    Floss
    Covino
Howard Lincoln
  • 235 Answers
Hi COVINIO. Yes, the "large black spring loaded magnetic screws on the sides of the mixer" are your mixer's brushes, which supplies electricity to the electric motor. (The black cap is the brush cover). I suspect that one or both of the brushes is (are) not seated properly. Did you remove the brushes to replace them or were you just inspecting them, when you replaced your plastic worm gear?
The brushes need to be installed so that they both seat correctly on the armature's commutator. See the illustration below:
I'd suggest removing them again and making sure the concave contact face rests completely on the armature’s commutator. If you've turned it 90 degrees too much, it won’t seat properly and you get no power to the motor.
It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 47, Brush holder assembly that includes #28, 32, 33, 34 & 46 which is the brush holder insert, and Illus. No. 29, brush & Spring assembly respectively. The illustration along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
Posted on Jan 29, 2010
Testimonial: "Dear hslincoln,Thank you for your very helpful link to diagram that showed exactly what to. It was fixed within 3 minutes"
  • 3 more comments
  • Howard Lincoln
    Howard Lincoln Feb 25, 2010
    Hi Floss, Thank you very much for your kind words and offer of a payment to PayPal. The knowledge that my solution helped get your mixer running again is more than sufficient compensation. If you still feel a need though, offer what you would have sent to PayPal to your son for his help or make a donation to Haiti Relief in my name. That would be appreciated.
    Wishing you a great weekend! - Howard, Burke, VA
  • torsoboy Nov 14, 2010
    Although I knew that my brushes were replaced incorrectly, I couldn't figure out the correct way to put them. I tried changing them around for over an hour, and it *seemed* like I had tried every possible different way, but nothing would work. As a last ditch effort, I got a flashlight and looked into the screw holes to see if I could see anything different that might help me know which way the brushes were supposed to go. And sure enough, there was! The brushes have a corner that is notched out of them, and if you look into the screw holes on the machine you can see one corner in each of them that is different than the others as well. I matched up the notched corners on the brushes with the corners that are different in the screw holes, and presto! Worked like a charm! I should have started with a flashlight to begin with. :)
  • stine3775
    stine3775 Jun 16, 2012
    Thank you all so much! I was all proud of myself for replacing the worm gear- but forgot I had 'played' with a few other things before that. The flashlight was indeed key!
  • stine3775
  • stine3775
    Thank you all so much! I was so proud of myself for fixing the worm gear, I'd forgotten I'd 'played' with a few other things before figuring that out. The flashlight was key to getting it working again. :)
Why wont my classic kitchenaid mixer switch off
Good Morning,
There is a spring inside your mixer attached to the speed control switch and speed control arm, the spring can sometimes get caught on the slide bar that is just below it inside the mixer. The other reason is that the speed control switch plate in the rear of the machine (that the spring attaches to) vibrates the three speed adjustment screws out or in and the spring will pull the speed switch (control arm that you use to control mixing speed when using the mixer) back to the stir position after you try to turn the mixer off.
If it is a spring problem you will have to do a full tear down to get at the spring and either free it or replace it. If it is a problem with the adjustment screws on the speed plate, that can be handled at the rear of the machine and is twice as easy to get at but sometimes much more frustrating to adjust. There are "YouTube" videos on the internet that will walk you through the process of adjusting your speed control plate just Google "adjusting speed on kitchenaid mixer" I hope this helps. please let us know if it does and if you have other questions just post them here and we will "FixYa"
Sep 11, 2014 | KitchenAid K45SS Classic Stand Mixer
The bushing in my kitchenaid KSM 90 cracked in half, how do I get it out of the hole?
Try tipping the mixer on it's side. the brush holder is a solid brass piece that goes all the way to the armature. You might also try fishing with a hat needle or a dental pick. If it truly is stuck in there and will not come out you are into a complete motor tear down to remove the brush holder to get at the culprit..
Sep 02, 2012 | KitchenAid Food Mixers
MY kitchen Aide mixer was running alittle rough /loud and now has stop completely. It is approx 24 years old and has never had any problems. It is hard to find a local repair [place. any suggestions
Two things you can do for a 24-year old machine:
1. Replace both motor brushes (Black large plastic Caps on each side
of the Moto Housing). Without these, the motor wouldn't even run.
2. Replace the Worm Gear (the cause of the Rough Loud noises)
Download a copy of the Repair Part List from Kitchenaid.com for
your model KSM90.
Also don't forget to tighten all the screws inside the mixers and use
fresh Kitchenaid Grade Food Grease for all the gears.
Jun 21, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
I took out the two black flat screws on the side of my KitchenAid mixer and out sprung a spring and magnet. When I replacter them my mixer won't start...
It sounds like you removed the brushes, look in the hole and determine the orientation of the carbon brush( what you describe as magnet). Rotated 90 degrees may keep motor from running...
Mar 12, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I have kitchenAid KSM150PS. I was grinding Chicken, which I've done many times before. This time the motor began to strain to the point that it did not sound good. I turned the unit off, let it cool for a...
Hello Salsaenz,
Yes, the carbon brushes go in a certain way. If you notice the brushes have a notche cut out on one side. Take a light and shine it in the machine and you will notice a piece sticking down the notch goes that way. The notch changes from side to side so you will have to do this on both sides. This will put the power/brusches back in the proper way.
Thank you for choosing FixYa and do not hesitate to ask more questions.
Mar 09, 2011 | KitchenAid KSM150PS Artisan Series Stand...
The mixer turns on, motor is running, but the beaters are not turning
Most likely what has happened is that the gears have stripped. The gears inside are plastic but the spindle is metal. When a dough is too heavy and gets caught up in the beaters it tends to eat them. If you take it apart, you will probably find that the gears are shot.
The fix...order new gears, tear down the mixer and replace them. These gears really should have been metal! Check the sunbeam web site for authorized repair places to get your parts.
1. Remove the ejector button...it should pop out with a flat head screw driver. There is a small phillips head screw under it. Take it out.
2. Take out the screws on the bottom. This should allow the face plate on the mixer to slide off, allowing your motor assembly to then be pulled forward.
3. Remove the mounting brackets/shock absorbers...they are rubber u shaped items that hold the motor in. Once that is done, remove the black plastic bracket on the bottom; two phillip head screws. Then unscrew the two long screws underneath. they hold on the speed control electric board as well as the top to the gear box. Pop the silver fasteners on the side of the gear box and you are in. the gears should lift out. put the new ones in and do the whole thing in reverse.
hope this helps.
Nov 29, 2010 | Sunbeam 2350 Heritage Series Mixer
I took the two big black plastic spring loaded screws out and put them back in, now it's not working...
Hi, ANNEQUESTRIA, I hate it when that happens. Those ‘two big black plastic spring loaded screws’ are your mixer’s electric motor brushes. The slotted black threaded plastic parts are just the Brush Holder Caps and are protective covers to the brush holder assemblies. They allow access to the brushes when they need to be replaced without have to take the whole mixer head apart. What prompted you to remove them?
From what’s been done already, still I suspect that one or both of the brushes is (are) not seated properly.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your KSM90P mixer falls within this manual), and select the last file KSM90PSWW0.pdf (354.08 KB) listed under Parts List (16) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 32, Brush holder assembly that includes Illus. Nos. #18, 21, 22, 23 & 31, and Illus. No. 19, Brush & Spring assembly respectively.
The Parts List illustration along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA
Feb 07, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
My kitchen aid mixer would not turn off. I pulled
you have lost the internal spring on the slide arm. a common problem but now the speed adjuster has been let go in the back of the motor. Best return to service centre as requires complete dismantle to repair, sorry.
Sep 13, 2009 | Food Mixers
Springs on side under black screw, came out
Or, more helpfully, take them back out.  Look in the hole, and you will notice that when you look through, the hole turns square. At the end the square, there is a little tab / square in one corner.  It is generally *not* the same on both sides. You'll notice that the end of the piece you took out (the part that looks like a magnet) has one corner cut off -- so it's a rectangular box with one of the corners gone.  Line up the missing corner of the piece you took out with the corner that has the little tab -- this allows the piece to get past the tab and be fully inserted.  Reminder: check both sides, because they're not the same. And now, more helpfully, if you're curious, check out flea markets and get a broken Kitchenaid to take apart for $20 or so. Don't mess with your nice one. : )
Apr 24, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM90 gear stripped?
I just ran into this problem when the PLASTIC worm gear broke and then the mixer would not power on after I replaced the gear. The problem was due to the was I tried to dissasemble the mixer. I removed the two plastic screws near the top center of the mixer when attempting to disassemble. These do not have anything to do with the assembly it turns out the attached square pieces (attached to these screws by springs) must be in the proper orientation to run. I put them in the way it showed in a diagram but it did not work until I tried all four different combinations that they could be rotated. Two of the rotations on the square could be eliminated by closely looking at the end where it contacts the shaft. The round shaft marking will be evident on the square inserts. I'mnotsure how to better describe them, but the are attached by springs to the plastic screws on both sides of the top of the mixer.
May 31, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Food Mixers Logo
975 people viewed this question
Top Food Mixers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
john h
Are you a Food Mixer Expert? Answer questions, earn points and help others
