Question about Volkswagen PAC C2R-VW Radio Replacement Interface
How do I remove the radio from my 2002 VW passat?
Posted by mikelavq77 on
Wilson Martinez
  • 171 Answers
1.- Disconnect the negative battery terminal to prevent an accidental short circuit.But make sure you have the antitheft code in case you need it.
2 Insert the long ends of the 86-9001(especial Key)into the slots on the factory radio and pull out to remove. Note: Flat edge of key should point outward. one slot is located on each side you need 2 keys.
3 For single DIN radios with the pocket, remove the radio and pocket, then pull out on the plastic tray separating the dash cavity.
Posted on Jan 29, 2010
Vw passat radio removal
Buy the tool from the dealer.
Jan 22, 2012 | 2004 Volkswagen Passat 1.8
WHERE WOULD THE TOOL BE LOCATED TO REMOVE THE RADIO IN A 2002 PASSAT
There are none. Go to eBay and buy radio tool set...real cheap. ...or look for specifically VW radio tools.
Jan 06, 2011 | 2002 Volkswagen Passat
VW passat 2002 tdi- Alternator removal- Top bolt free and bottom bolt loose but cant remove the bolt as too long and keeps catching on fan. Stuck!! help
you have to lift engine a bit to make clearance. take engine mounts loose or contact vw dealer and talk to one of there techs
Dec 28, 2010 | 2002 Volkswagen Passat
Need radio codes for VW PASSAT 1999 gamma
Sorry...this code is only available from a VW Dealer or a Radio Decoding Service
Will not be available for free from anywhere on the Internet
May 25, 2010 | 1999 Volkswagen Passat
How do I remove the radio from the dash of my 2002 passat wagon?
There is special tool to remove the radio.Visit VW workshop
May 12, 2010 | 2002 Volkswagen Passat
2002 VW Passat GLX AWD, stereo stopped working
HI,
Passats can be reset if the radio is pulled out and the fuse on the back is removed. Wait for 2 mins, reinsert the fuse and turn the radio on. If this doesn't work, please take it to the dealer for the unlocking of the code, for which he may charge you some fee.
Do let me know if it was helpful.
Regards
Kanu
Sep 09, 2009 | 2002 Volkswagen Passat
2002 Passat won't start
We had the same problem. It was an expensive fix--there apparently was a problem with the onboard computer that would periodically lock out the ignition circuit. Felt just like a bad starter solenoid--but the part cost $800, plus labor, to replace. Ouch.
Jan 04, 2009 | 2002 Volkswagen Passat
Vw passat radio code
Passat 97 need to re-enter code ( 4 ) digit, however it shows the number 2 on the on screen when the radio is turned on.
Help. I need to know the steps to reset. thanks
Dec 13, 2008 | 1999 Volkswagen Passat
Volkswagen PAC C2R-VW  Radio Replacement Interface Logo
745 people viewed this question
Top Volkswagen Car Audio & Video Experts
Colin Stickland
Colin Stickland
gbob59
Harwoods Rd Garage
Are you a Volkswagen Car Audio and Video Expert? Answer questions, earn points and help others
