HP LaserJet 4 plus Printer Logo
Posted on Jan 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, the printed pages come out with a gray film over most of the page
Seeker5211
Level 3:
Genius:
  • Master 1,089 Answers
  • Posted on Jan 30, 2010
Seeker5211
Master
Level 3:
Genius:
Answers
1089
Questions
Helped
617750
Points
2611
Do a "half test". Print a few pages, as the printer prints open the top cover. Pull out the toner and look down at the paper. If it has the gray cast, you have a bad toner cartridge or a bad transfer roller.
It could also be a dirty ground. Try vacuuming out the inside of the printer especially around the transfer roller.
The pages have a very dark background and it is in the pattern of wide stripes
Open rear cover and check gray plastic film not torn or broken. If film broken printer requires the fuser replaced. This is not a user replaceable item as its quite a tear down to reach the fuser.
Image defects may also be caused by toner cartridge. Check toner cartridge for background issues. To do this print the printer's demo page and open door when paper is half in the printer. Remove the paper jam and check unfused image for defects. If defects occurs then replace toner.
1helpful
HP3330....machine is adding a wide black streak about 3 inches wide down the center of printed pages. Is this something I can fix ?
Check the fuser for the problem, look at rear of printer and open access door to fuser, look at gray plastic film if film broken replace fuser, if film has black mark replace fuser. Note replacing fuser NOT considered a user replaceable item.
Gray Lines print onto copies
more than likely its your drum unit could be upper fuser film but prob the drum
2answers
HP 1020 produces 2 grey lines at edges of page
it is the problem humadity or laser mirror is dirt clean it and then solve your problem
2answers
Gray background only on odd number pages
your cartridge is defective.. just replaced a new one.
Printing only in black
When you get the printer option page click on properties, in the main page there select gray scale printing. Click OK to get back to the print page and ok there to print.
Hp desk jet 920c ink cartridge
hi,
i think your color ink cartridge is near to empty that's why you are experiencing a pause printing..
try to replace it and try to print again..
rey...
HP K550 Prints Solid Gray Boxes Around Items
Hi drglass1 -
13,000 copies - that's awesome! although you've surely fixed this problem by now, for future refs or someone else searching for an answer... you might find this ref hp support helpful. happy printing!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00458018&lc=en&dlc=en&cc=us&lang=en&rule=35557&product=501369
Step 4: Clean the printheads
If the print quality is still bad, clean the printheads:
1. Make sure the printer is loaded with unused white paper.
2. Open the printer Toolbox and select the Printer Services tab.
3. Click Clean Printheads . A Clean Printheads window opens. Click Level 1 Clean .
4. Examine the page that prints for print defects.
a. If there are no defects, click Exit . Stop troubleshooting here .
b. If there are defects on the page, click Level 2 Clean . 5. Examine the page that prints for print defects.
b. If there are defects on the page, click Level 3 Clean . Note that Level 3 cleaning uses a lot of ink – it is not recommended if the cartridges are low on ink. - JW50
HP Laserjet 1320 - Gray bars printing on sides of paper with dark dots
It sounds like a defective toner cartridge. Try replacing it. If that does not cure the problem, then the fuser assembly needs to be replaced, in which case it is probably cheaper to buy a new one.
Good luck
John
k24674
Grand Canyon Tech
Grand Canyon Tech
