Coffee Makers & Espresso Machines Logo
Question about Bunn NHBX-B Contemporary 10-Cup Home Coffee Brewer, Black
Can't find my BUNN NHBX-B manual...can I find it online somewhere?
Posted by dorkinshorts on
Anonymous
    Problem Solver:
  • 8 Answers
I work for BUNN. Here's a link to the manual for your NHBX-B
http://www.bunn.com/pdfs/retail/usecare/41756.0000_STX_NBX_U_C_English.pdf
Posted on Feb 01, 2010
Anonymous
    New Friend:
    Problem Solver:
  • 12 Answers
1 Related Answer
Anonymous
SOURCE: No manual with Bunn NHBX coffee maker.
Leave the unit unplugged and add a carafe of water to the top reservoir.
Close the lid.
Wait a bit to make sure the water has drained into the tank.
Add another carafe of water to the top reservoir.
Place carafe on warmer plate.
Close the lid.
When water stops going into the carafe, you may plug the machine in and make sure the "travel switch" is in the ON position. ON = |, OFF = O.
Wait at least 15 minutes for the water in the tank to heat up, and brew as you normally would for other BUNN coffee makers.
Posted on Mar 21, 2010
How to fix a Bunn NHBX that produces warm, not hot, coffee?
Thermal fuse is blown. Above and almost behind tank, and most likely brown. New one at www.bunn.com
How to remove the top water resivour from a nhbx bunn coffee maker
lift filler led and remove 2screws on top of reservoir
Then remove 4 screws that hold the reservoir on an you should be able to lift it off
Bunn nhbx leaks water
Jun 30, 2014 • Bunn NHBX
I have a bunn coffee maker, model NHBX-B. The warmer switch is not working anymore. Where can I buy a replacement switch for it. The switch is located on the top and has a light in it.
What a scam. I am a professional electronic technician trained
in safe practices in electrical work and they won't sell me the replacement switch. I will source a suitable replacement from one of the big electronics supply catalogs. This will be my last Bunn coffeemaker.
4helpful
I have a bunn coffee maker the nhbx is the # it is leaking water from the resevoir
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
2answers
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
Top Bunn Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Steve
john h
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
