Question about Magicard Alto Card Printer
My magicard alto prints fine except the color quality is not very great. when i use the color ribbon and print black letters with it the letters come out gray and not black and it has a problem making the hunter green color. it prints it more blue than green.
Posted by kencookjr on
Anonymous
    New Friend:
  • 7 Answers
The printer driver must be set to print text with the K resin panel.
If the text is part of a bitmap image and not a true-type font then it will print from the coloured panels and be dark grey.
To create the correct green on the card you need to change the RGB values so it prints correctly but look wrong on the badge design program. Even different printers print the same colour differently.
Posted on Feb 17, 2010
I GOT COLOR RIBBON BUT THE PRONTO SED TO ME THAT A HAVE TO CHANDE BUT THE RIBBON IS NOT DONE YAT!!
Hello fabiogb_765,
Did you notice an error number when your printer tells you that it is out of dye film?
The error number is important.
Regards,
MC.
Jan 11, 2013 | Magicard Enduro/pronto Ymcko Color Ribbon-...
Hello! I am writting this message regarding with my magiicard opera 100 that does not work. I am using it in school office right now to make student ID cards, however it is not working. The problem is that...
From your description, there are only a few possible causes:
1. The ribbon you have is not the correct one for your printer model, or is not a genuine Magicard ribbon. Where did you purchase?
2. The printer has old "firmware" that doesn't recognize new ribbon RFID tag info. (firmware is an internal program on the printer that should be periodically updated - free download from Magicard web-site: Magicard ID Card Printers Identity Solutions ).
3. The ribbon-sensor has failed (printer cannot see / sense the ribbon's presence).
If we can help further, just reach out to us!
Safe-Card ID Services
Charlotte, NC USA
https://www.safecardid.com/
Sep 25, 2017 | Magicard Opera 100 Card Printer
Printing in black mono only. A portion of the
Common problem is a dirty card, make sure you handle the cards by the edges and not the surface as oil from finger residue will cause a misprint on that part.
This problem can also be caused by improper or too low of a setting for black intensity, where the printer does not apply sufficient heat to transfer the color onto the card.
Also check for a faulty ribbon, if the ribbon is not properly stored or is more than 3 years old, it can also cause this issue.
-- The Pros at www.DiscountIDStore.com
Nov 12, 2010 | Zebra P330i Thermal Card Printer
Really poor quality of the printed picture.
Have you cleaned the printer using a Magicard cleaning kit? Your printer neds to be cleaned using a cleaning kit every time you cahnge dye film to maintain a top quality print.
Cleaning kit contains 10 cards, 1 pen and 5 rollers - P/N M9005-761. You can buy it from your Magicard approved dealer or contact Magicard directly who will direct you to a dealer - [email protected]
www.magicard.com
Feb 15, 2010 | Magicard Rio Card Printer
Lokking to replace my exhausted printer ribbon
Search online for magicard dyefilm and you will find many suppliers.
Nov 07, 2009 | Magicard Alto Card Printer
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Just want to print black !
hallow ,,,if your lookin to just print black and white so .while printing ,go the printing properties or prefrencies ,,in the colour option click just use black and white
Jan 10, 2009 | Office Equipment & Supplies
Magicard alto
Hi There,
Sorry to hear you are having a problem with your Alto printer.
A common fault is where the dye fil cassette runs out, the user is warned, but they keep clicking on 'OK' rather than opening the lid and checking the film.
To resolve this, first of all, upgrade your printer's firmware to the latest version (V4.06).
You can download this by following the link below;
http://www.magicardonline.net
Enter your printer's serial number in the QuickSearch box at the top right of the page.
You will then be offered the latest firmware version to download.
Secondy, there is a small 'O' ring drive belt for the dye film advance motor. This is behind the right-hand side panel. This belt may have either come off the pulleys, or it can sometimes double back on itself and get trapped. In either case you may need to replace it to be on the safe side.
The Magicard part number is RIO/0037/R
If you contact your local Magicard service centre they will normally stick one in the post free of charge.
I hope this information is useful to you.
With Best Regards,
MC.
Oct 17, 2008 | Magicard Alto Card Printer
Zebra 330i 4c problems
Hi, did you try this?
Go to Printers and faxes, right click on the Zebra printer and go to properties. Under Device Settings, go to tools, then properties. At the top is a command window, in this you type the command !SA, that's an axclaimation mark followed by the capital letters S and A. This is the command to recalibrate. click execute, the printer will wizz and whir and then say ready. I've just done 20+ cards on mine and they're all fine.
Mar 24, 2008 | Office Equipment & Supplies
Magicard Alto Card Printer Logo
361 people viewed this question
Top Magicard Office Equipment & Supplies Experts
Safe-Card ID...
Harrie
Tom Chichester
Are you a Magicard Office Equipment and Supply Expert? Answer questions, earn points and help others
