Question about GE (PSS26MSRSS) Side by Side Refrigerator
Check the sensing arm on the side of the icemaker. The arm stops the icemaker when your bucket fills and the arm cant move all the way out and then back in. Make sure the ice is building up in the arms way so the arm can sense it. Otherwise the only other option is to replace the icemaker itself. GE does not sell parts for the icemaker and the only repair for it is replace it. Hope this helps you.
Posted on Jan 28, 2010
Nov 14, 2012 | GE Monogram ZDIS15CWW High Production,...
Hello - If your ice maker has stopped producing ice completely, you can try to check the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Oct 03, 2012 | Frigidaire FRS3R5EMB Side by Side...
Aug 04, 2012 | Whirlpool Gold Series GI15NDXT 15"...
Jul 08, 2012 | Frigidaire Refrigerators
The ice
maker not working.-------------
Its the problem of water inlet valve. It's a
dual valve. This valve has two tubes in it. One for water dispenser and one
for ice maker chamber. The one side of valve is working, but other side of the
valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the
problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 10, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Aug 22, 2011 | Kenmore Refrigerators
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
Jul 02, 2011 | Amana 22.6 cu. ft. Side-By-Side...
150 people viewed this question
