Try deleting all paired devices first, Menu / settings / paired devices. The remove the battery from your mobile phone for ten seconds. Then try pairing again, this should do the trick, if not the parrot may need a software update.
you will have to pair them together again, search for devices from your phone and select parrot, then enter pin code 1234 when prompted, this should then pair again.
What's the issue? Can't get it to pair? My 6220 wouldn't pair with my Parrot either.
Try sending an MP3 to the Parrot kit. I couldn't even get the Parrot BT
in my car to ask for the BT password numbers but found out to try
sending an MP3, which will fail by the way, and it asked for the
password finally.
There was an error in my case, but then the
phone asked to connect to the Parrot again and the pairing worked.
There
is an issue with newer Nokia phones, something I will be thinking about
next phone upgrade.
hi just had the same problem solution : hold the answer and hangup buttons down for 5 seconds {press red and green and hold} the parrot kit will then tell you it is erasing memory then it will say ready for pairing turn on your bluetooth on your phone doe a search find and select parrot enter default code 1234 when prompted as a pin and away you go hope this helps bob
