Tv was working fine i tried to turn the tv it has no power i tried the reset button i tried a diffrent power outlet there no power getting into the tv could you tell me what part went bad so that i could replaced it thanks luis arc.
Check the fuse on theit my be blown if it is check the diodes around it they may be shorted also check the cap also where the power come into the board
This is just a shot - but it worked with my Sony (same problem).
Pressed remote power on button AND held Power button on TV on at the same time.
Set clicked 4 or 5 times and then came on....
Other, most have a (VERY small) reset switch on the rear - near where the power cord enters the TV... Use a flashlight and a mirror to locate it on your set....
Try to reset first if nothing happens we proceed another solution;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time. 1.Unplug the TV power cord from the power outlet for 6 hours.in order to dessipitate the charge current. 2.Unplug any connected devices (Satellite, DVD, Set-top boxes, etc...) 3.Press and hold the TV power button for five seconds. 4.Plug the TV power cord back into the power outlet and turn on the TV. 5.Open the on-screen menu to confirm that the TV is responding again. 6.Turn off the TV and reconnect the devices. 7.Turn on the TV.
Resetting the TV If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows: NOTE: Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time. 1.Unplug the TV power cord from the power outlet for 4 hours. 2.Unplug any connected devices (DVD, Set-top boxes, etc...) 3.Press and hold the TV power button for five seconds. 4.Plug the TV power cord back into the power outlet and turn on the TV. 5.Open the on-screen menu to confirm that the TV is responding again. 6.Turn off the TV and reconnect the devices. 7.Turn on the TV.
1.Unplug the TV power cord from the power outlet. 2.Unplug any connected devices (DVD, Set-top boxes, etc...) 3.Press and hold the TV power button for five seconds. 4.Plug the TV power cord back into the power outlet and turn on the TV. 5.Open the on-screen menu to confirm that the TV is responding again. 6.Turn off the TV and reconnect the devices. 7.Turn on the TV.
NOTE: Some
save time.
NOTE: Some
save time.
