The clock uses a 12-hour digital indication...... Press and hold the select button...... The setup display appears...... Press the select button repeatedly until “CLOCK-ADJ” appears...... Press (DSPL...... The hour indication flashes...... Rotate the volume control dial to set the hour and minute...... To move the digital indication, press (DSPL...... Press the select button...... The setup is complete and the clock starts......
Push in and hold volume knob. When clock adjust displays on radio push fast forward button to select hour or minutes. Adjust hour or minutes by turning volume knob. Press volume knob in when done.
First make sure your radio is off. Then push in the volume button until it says set clock. Use the seek buttons to select hour or minutes. Turn the volume button to the desired time. If the radio is not shut off you will not get the option to adjust the clock but instead the option to adjust the treble or base etc.
I have no trouble getting to the "clock set adv". After that, nothing moves it to the clock numbers and gets it to blink so I can set it. Thanks for telling me how to do it IF I ever get to that spot.
