LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone Logo
Posted on Jan 28, 2010
I can't charge screen image, help meee!
I can't charge screen image, i have a microSD of 8gb but the phone says thai i don't have memory. please help me!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
37
Points
Jus change ur memory from phone mem to ...external mem.by the memory management tool inside ..ur menu..
love ya .tc
Most apps don't run. Operi mini and nimbuzz do
You should not be surprised with these developments really.
Unless I am mistaken/misinformed; your phone has only 350Mb internal storage space and a capability to add-on a microSD card up to say 8Gb.
It appears the internal memory is filled/cluttered up already and as such your phone does not have room to perform/execute certain processes.
Attempt to free up internal memory space by transferring a fee apps to a mi roSD card (which you have to purchase and insert in your phone first).
See if other unresponsive apps run now or not.
Do post a feedback/update here please
1helpful
2answers
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
2answers
Slow,and internal memory almost full i barely have only like 3 or 4 apps because it wont let me installmore. and i keep cleaning the cache and deleting the texts but it does not help.
this issue appears to have nothing to do with how much space you actually have, whether it's on the SD Card or on the phone - it appears to be a big HTC Mail bug that's just crushing my phone as well, no matter what I purge or reset - there is a long thread here about it -forum.androidcentral.com/.../12215-htc-mail-memory-leak-bug-phone-storage-getting-low-2.html
it's very frustrating and will probably cause me to take back the phone
4helpful
2answers
Not enough memory in my music player can you help me please !! thx !!
If the built in memory isn't satisfactory, you can allways buy more.
This phone supports microSD cards, up to 8GB. They will cost around 10-15$.
1helpful
Bagaimana cara memasukkan kartu memory nokia n95 8gb saya sudah membongkar nya tapi saya tetap tdk tau jg di mana di masukkan kartu memory trsbt
Nokia N95 2 8GB model has its internal 8 GB memory which cannot be changed. Also, it doesnt have MicroSD slot.
Nokia N95 8GB 2 model memiliki memori internal 8GB perusahaan yang tidak dapatdiubah. Juga, tidak memiliki slot MicroSD.
How to fix the balck n95 8gb ..... how put memory card pls help me....
Hi!
Locate the microSD card slot. If the screen is facing up and the front buttons are closer to you than the screen, then the slot is on the left side of the phone, close to the front keys.
Insert a microSD card into the slot. Make sure that the metal contacts on the card are facing up and towards the phone.
Hope this helps.
9helpful
2answers
My LG Neon is not recognizing the microSD? card. it says "not supported". the memory card itself is microSD HC 8GB. it currently has music on it. not sure if that has anything to do with it.
Hi,the music on the memory card has nothing to do with it,the problem is that the memory card is not supported by the phone,the phone uses a microSD card quite alright but the maximum SD card it supports is 4gb microSD card that is why the 8gb microSD card is not supported by the phone.
so i'll suggest you get a 4gb microSD card.
Take care
MicroSD card has "fatal errors"
hi i have a 4GB microSD memory card in my blackbery and it started not reading properly not it says the memory card cannot be accessed due to fatal errors i now cant access nither pictures oe music on it can someone please help me
My phone wont reconize my microsd card help!
this only means that the micro card was defective.
better to replace it.
45helpful
7answers
Please Unlock my MicroSD password.
I forgot my MicroSd password.Please help me to remove it.I am unable to access my MicroSD card.I have Nokia 6300
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
