Watches Logo
Posted on Jan 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bakelite antique mantle clock just bought, but no instructions of how to get it going. Ive got the key and pendulum but dont know how to set it up. Can you help?
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Jan 28, 2010
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1814146
Points
13579
First you have to wind up your clock using the key supplied. The pendulum suspension spring should start to swing quite fast. Stop it swinging with your fingers and hook up the pendulum. When done, push the pendulum to whatever side and release it to start the swing - the clock should start ticking in normal order. If there is no special bar on the back of clock movement for adjusting hands, then hands must be adjusted from the dial side by moving minute hand clockwise. Move the minute hand with your finger clockwise to the desired time, at the same time do not catch hour hand, as this may end up with the incorrect time displayed. Rate me, plz.
I have a wall clock, with metal 'scroll work' the clock runs but the pendulum doesn't swing. How to repair the pendulum mechanism?
If your wall clock is running but the pendulum is not swinging, it may be due to a few potential issues with the pendulum mechanism. Here are some steps you can take to repair the pendulum mechanism:
  1. Check the suspension spring: The suspension spring is a thin strip of metal that hangs down from the top of the clock and holds the pendulum in place. Check to see if the suspension spring is properly attached to the clock and if it is straight. If it is bent or damaged, it may need to be replaced.
  2. Check the pendulum leader: The pendulum leader is the part of the clock that connects the pendulum to the clock's movement. Make sure that the pendulum leader is properly attached to the clock and that it is not bent or damaged.
  3. Check the escapement: The escapement is the part of the clock that controls the swing of the pendulum. Make sure that the escapement is properly lubricated and that it is not damaged or jammed. If it is damaged or worn, it may need to be replaced.
  4. Check the beat setting: The beat setting is the adjustment that ensures that the pendulum swings evenly. Make sure that the beat setting is properly adjusted by moving the pendulum to the left or right until it swings evenly.
  5. Check the weights: If your clock has weights, make sure that they are properly attached and that they are not obstructed or damaged.
If you've tried these steps and the pendulum still isn't swinging, it may be best to contact a professional clock repair technician for further assistance. They will have the expertise and tools needed to properly diagnose and repair any issues with your clock's pendulum mechanism.
Feb 18, 2023 • The Watches
2answers
This clock has been in my family for manyyears and it has recently stopped working. The pendulum no longer swings continuously and i dont hear a ticking when i do swing it. My grandpa said something about...
It sounds like the drive spring might be worn. A Good clock and watch specialist will be able to overhaul and service the clock for you. It might cost you a bit more money but if it is a family clock it could be worth it.
Dec 13, 2019 • The Watches
Can you replace mechanical movement with a electrical movement and maintain pendulum movement?
hi,
  • would be nice to know if this is a full blown grandather clock. Part of the personality of a clock is its movement. anyways I would leave it if that movement is antique at all as mechanical movement in anything will not depreciate. again I am at odds why someone would want to do this. A local clock shop would have more answers for you. if its a mantle clock or something other than that they make retro kits listed on the link
https://express.google.com/u/0/product/13586318207937065316_16333649438642067625_118724597?utm_source=google_shopping&utm_medium=tu_cu&utm_content=eid-lsjeuxoeqt,eid-wcyzltjlv,eid-ygcnqnyulq>im=CIm0s93KyZ_i4gEQ746emJCqhMLFARjw2oYHIgNVU0QokIeF3gU&ut
Sep 24, 2018 • Watches
1helpful
I have a 1983 reproduction of the limited edition Royal Observatory conical pendulum clock The parts for the pendulum may not be complete. I need instructions or schematic to see if it is all there and...
Hi Petah 920...I have also aquired the same clock, with the pendulum and other parts missing. I intend to fabricate the missing parts ( I am a clockmaker) and engineer. My problem is not knowing the exact parts, I have contacted Thwaites
Aug 09, 2010 • Watches
I have just bought a Enfield Bakelite Mantle clock. Exceelnt timekeeper however after abot 22 hours it stopped. Again today after about 8 hours. Is there another problem apart from needing wound up? I...
How old is your clock?
If it is fairly old then it could just need a clean (by a professional!).
Over winding is a strange term which I have never quite understood in all my career as an engineer. I have known a brand new watch to fail when bought fully wound and I think that it may have been wound too hard and the mechanism jammed. I don't think that this is the problem in your case.
Mar 14, 2010 • Watches
3helpful
Antique Forestville Mantle Clock
Middle Key hole for the time.
Left side is for Chime
Right side is for the strike.
r/
David
1helpful
2answers
Does anyone know where to get a replacement 'movement' for the Michael Graves's Alessi mantle clock.
Yep - I know a clock repairman in California who still has some of the original Hechinger Quartz Movements for the Alessi pendulum clock . Definately worth repairing .
Jul 13, 2009 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
