Question about Apple iPhone 3G
I Got Iphone 3g and got Dropped on water, half of the phone, i Dried the phone and the phone turns on and but the phone wont has signal what i have to do???????????
Posted by carmelo_f on
jacobcheatha
    New Friend:
  • 19 Answers
Take out your sim card whip it off, and let the top part dry out for a while without the sim card in it... :)
Posted on Jan 30, 2010
My phone was submerged in water for about 90 seconds. Will it still work and how long should I wait before trying it?
You should probably wait for a few days to ensure it's completely dry on the inside. I have heard other folks suggest that putting the phone in a bowl of white rice for a few days is a great way to dry it out. The rice will absorb the moisture.
Did the case cover the entire phone or just the sides and back like most?
Jun 01, 2012 | Apple iPhone 3G
Iphone does not connect to wireless networks anymore
It would appear that the internal antenna is faulty and will need to be repaired.
Oct 27, 2008 | Apple iPhone Smartphone
Yesterday my iphone felt down and now the lcd wont turn on and the phone go on restore mode good
Hello
The internal parts might have got damaged when you dropped it. You will have to take your phone to the nearest Apple store and get it repaired.
Feb 25, 2011 | Apple iPhone 3G
Dropped iphone in water apple wont go away
1) Immediately turn phone off by holding down power button and sliding to off.
2) Use canned air duster to blow water out of all holed in the phone such as headphone port, sim tray hole and the bottom port
3) Place phone in sealed baggie containing silica packs (come with shoes/coats, etc) or uncooked rice for at least 24 hrs.
4) In this time, DO NOT try to power the phone on, this can easily cause a short and ruin a phone that may have otherwise survived.
5) Wait 1 or 2 days and remove from the rice/silica which should have drawn out the water. Now try and power on the phone. I have seen these steps save a soaked iphone more than once.
Good Luck
Feb 24, 2011 | Apple iPhone 3G Black Smartphone
IPhone Smartphone: i dropped my apple 3g iphone in water after 2 hrs ...
Do a search for water damage iphone repair on craigslist in your area. There are usually several people with local shops that can fix this for you.
May 17, 2010 | Apple iPhone Smartphone
Wet (damp) iphone no sound!!
This has been happening a lot with Iphones and also with the microphone input. either u need to update ur handset or revert to see if this is the problem...
Also save all ur info on your computer and do a master restore from the computer on itunes.
Call customer care.....If you are still in warranty Your item can be replaced......I dont think water is the problem because you would have issues with your screen ..I do not sufggest saying that is the reason either because apple does not cover items if it is water damaged.
Go to this specific page to talk with an apple expert. of these problems are not resolved.
http://www.apple.com/support/expert/
Mar 09, 2010 | Apple iPhone 3G Black Smartphone
I dropped my phone today and now it wont work
When you dropped it you loosened up the digitizer connector which is number 2 under the screen. Open your iPhone and resit that wire firmly back in. That should fix the digitizer not working.
If its a 3G just unscrew the 2 screws at the bottom and use a suction cup to remove the screen. Easy. But if its a 2G then Good Luck.
Jan 29, 2010 | Apple iPhone Smartphone
My home button on my IPhone is not working. Last night i dropped it in water and quickly retrieved it. i dried it off with a blow-dryer and now the only thing that doesn't work is the home button.
If your device gets covered in water, act fast and rationally, and you may be able to save your device.
1. DO NOT TRY TO TURN IT ON
2. Pull out the battery.
3. Please your device and battery into a bowl of uncooked rice to absorb any moisture.
4. Please it in a warm, dry place where it can receive direct sunlight.
5. Be patient. It is recommended that you leave it in there for at least 48 hours.
6. After 48 hours, put the battery back in and power on.
Oct 17, 2009 | Apple iPhone 3G
I just drop my iphone on the water at first it wouldnt work or turn on but after the phone dried up.
IF YOU GET IT WET NEVER TRY TO TURN IT ON PUT IT NEXT TO A HEATER FOR A DAY AND AS SOON AS IT DRY ITS GOOD TO GO
Sep 21, 2009 | Apple iPhone 3G
Apple iPhone 3G Logo
107 people viewed this question
Top Apple Cell Phones Experts
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
Matthew Boulden
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
