Question about Nikon Coolpix S220 - Aqua Green 2.5" LCD Digital Camera
Can't transfer pictures to computer
Nikon coolpix S220 won't transfer pictures
Anonymous
    New Friend:
Found solution thru a google search, unplugged the camera from the computer, turned the camera off, plugged it back in and then turned it back on, the camera icon finally showed up in the Nikon transfer program
Posted on Jan 29, 2010
Nikon coolpix s220 - USB device not recognized. The USB is fine since it works with other devices and the USB cord is fine since it works on a different computer. I tried a driver update but I get a...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Sep 03, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Am unable to copy images to computer from my nikon s220..pls help:-(
There is a very easy way to download those pictures to your PC.
Checkout this tip that I wrote about that.
How to easilydownload Pictures from Digital Camera
heatman101
Apr 21, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Nikon coolpix S220 how to erase all pictures at once
hi kategralton, in play mode press menu key and choose format card then ok.
regards
Mar 22, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
The display is distorted but the lens operates properly.
Does the distortion affect the pictures too? I mean do you see the distortions on the pictures when you transfer them to the computer? Please answer this question as it is important to determine whether its an image sensor fault or a problem with the screen itself
Feb 09, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
My nikon coolpix s220 won't transfer pictures to my macbook. I have done it before, but not in a while. I connect the camera to my comp. but nothing happens. I have no camera card slot. What can I do?
You can plug a card reader into the USB or FireWire port.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader. This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Aug 13, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Blurred pictures
You may be using too slow a shutter speed, resulting in either camera shake or subject movement. See what the manual has to say on this.
Jun 29, 2017 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
How to upload pictures from a Nikon coolpix to a dell computer
download your s220 nikon driver here...
http://support.nikontech.com/app/answers/detail/a_id/61
IMPORTANT to install the software before pluging in the camera!!!
But my ideal solution to downloading pictures is to remove you storage media from the carmera and use a card reader...
doesn't waste batteries, much quicker, needs no software to work...
please leave feedback if helpful
Oct 25, 2009 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
I have a nikon cool pix s220 it will not transfer pictures from the camera to the computer. I plug it in and turn it on and nothing. i am running windows xp 3
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Nikon Transfer.
Sep 13, 2009 | Nikon COOLPIX S200 Digital Camera
Nikon Coolpix S220 - Aqua Green  2.5" LCD Digital Camera Logo
613 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Nikon Camera Expert? Answer questions, earn points and help others
