SOURCE: VulcN MODEL gc04C CONVECTION OVEN WON;T IGNITE ER-05 CODE
thaddeus,leave the ignitor in its place and try to bend/adjusted close to the burner.if you dont hear a click--click noise its not sparking and the problem may be the ignition board.if you do hear it check the orange/black wire to the ignitor.it could be damaged and the spark is being grounded onto the frame of the oven.the easy way to tell is if you hear the spark but no gas try to light it manually,if sucessful clean out the pilot--if this doesnt work replace the ignition cable.i service these ovens alot.if you need a part let me know and i can give you a part #.
SOURCE: Flavel 100 finesse problem
Check the thermal fuse it is located on a bracket at the rear of the fan oven.
SOURCE: bought oven second hand so no model no. it is a
most model numbers are located around the frame of the stove, inside the drawer area or on the oven door, call the manufacturer, most have a toll free number. Check to see if the fuses are okay first, if one is out, that could weaken the system. The fan is probably convection, and your controls will have a convection feature. If the fan has ceased to work, just use the regular bake mode.
SOURCE: right side stove top igniters dont fire off of right side knobs+
clean the pilot jets out sonds as if they are clogged. if the right side is only being lit once the left side is on then you better not run the right until you do get it fixed as more than likely whats happening is the enough gas is traveling through the chamber to be ignited by the left sides flame and that can be dangerous, however your stove uses an electronic lighter all you need to do is clean the contact points so that they will spark cleanly if it still won't light you need a repairman.
SOURCE: My Whirlpool kitchen Range is
Hi You
are right it is the igniter that is bad and should be replaced. Please check
this video on how to replace it: Hope this helps...please post back for further assistance. Daniel
Hi
You
Daniel
