My IR 6000 canon copier cut printing in back side approx 1 inch but in auto Zoom & image entire mode printing is ok both side. This condition is same as both type of paper . DOCST + 5 LA- SPEED + 7 SIZE- SW 0 REGIST 0 ADJ-REEF 0 RG-MF 0 HELP ME
press setting/function button then 2&8 same time with two fingers then gain press setting
screen will change to service mode
select mode-copier-function-clear-ok restart machine.
Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Nov 22, 2014 - 3 posts - 2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key.
Error Code canon image ronner 2202N
Aug 21, 2014 Canon IR 2200 error E000001-002
Jun 18, 2009 More results from www.copytechnet.com
1) Press the asterisk key ' ' on the control panel. 2) Press '2' and '8' on the keypad at the same time. 3) Press the asterisk key ' ' on the control panel.
Then choose COPIER, and FUNCTION, find P-PRINT.
Function P-PRINT,Prints the contents of <ADJUST, OPTION and COUNTER> of service mode. Be sure to execute this mode before replacing the image processor PCB. n Operation 1) Select the item to highlight, and press the OK key. A total of three pages will be delivered. n Source of Paper • If a source is selected on the Basic screen, that source will be used. • If auto paper selection is enabled, the topmost cassette will be used.
you have miss regrestion there are several ways to correct this process 1-go into service mode -function-clear-dc con -ok then take machine off unlug from wall outlet replug turn machine on 2-replace your itb assy. 3-there is another way but you have to be next to the machine and fimilar with second level service mode.
Set the roll size to 44 inch, set your left margin to 0 (in your preprint software), experiment. With margins set at 0, using Onyx Productionhouse 7.3, the 9800 will print approx 41.8 inch image on 42 inch roll 43.8 on 44, etc. This is considered borderless printing. No matter what size roll you tell the printer it has in it, it will print to about an eighth to a sixteenth of an inch short of the paper's actual edge (that's the left side of the roll paper coming out of the printer - the right side of the print). If you load, for example, a 36 inch roll, tell the printer its a 44 inch roll, and send a 40 inch wide print, with a left margin of 0 it will print around 35.8 inches, cutting off the image just before it would overprint and get ink on the machine (1/8 - 1/16inch before the edge of your 36 inch stock). It is possible that these tollerances will be different depending on what software you send your images with... hope this helps!
