Did you get an OBD code? The OBD error code would give you a better idea as to what is wrong. your question alone is insufficient information to give you an informed reply. It could be one of several things to deal with. Get yourself a cheap $50. scanner at your local Autoparts. This will give you the error code. You can look at the following page http://obdii.pro/en/model/honda to find the code numbers relevant to your situation. just scroll down and highlight and click on your specific type of vehicle and search and choose the error code that you got- to get more information about your vehicles malfunction(s)
Remove all the printer settings, and swich off the printer.And restart your system. install the drivers with MX 320 CD. Once it ask you to switch on your printer, please switch on then the printer it automatically it will detect and it will finish this.This is the normal installation procedure .
If you want more help from me please give me the details of the OS and error code and other's.
m.cuci lg toplouding error DE. pada dasarnya pintu atas dilengkapi swich tapi kenapa model ini kok gak.terus gimana cara ngatasi door swich ini. mohon pencerahan
Consult your owner's manual for error codes. You have a disk/disk reader problem. A similar model Pioneer Manual indicates FRMTREAD as what is displayed while reading a disk. Error 15 equates to "The inserted disk does not contain any data". If this occurs with multiple disks, try the disks in a known good cd player. If they work there, it is likely a reader problem (alignment, bad reader, etc.) which would likely not be worth repairing or replacing in that unit.
