Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat Logo
Question about Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat
What do i use to wash my car seat cover - Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat
Posted by k_underwood on
Anonymous
    New Friend:
I used a liquid washing tablet and did it on a cool wash in the washing machine. I found if I used washing powder it left white marks. Also, make sure you won't need it in a hurry as really you need to leave it to dry for about 48hrs.
Posted on Feb 17, 2010
gokleen carwash
Following solutions can be used in order to easily clean car seats
1) Use club soda.
2) Use a baking sodas solution
3) Use laundry solution
For help visit: https://gokleencar.com
Posted on Nov 30, 2019
5 Related Answers
Anonymous
SOURCE: maxi cosi car seat cabriofix
What seems to be a sewn-up loop, is actually easy to unattach, but the trick is not explained in the manual.
Where the end of the strap seems to be holding to the seat's plastic shell, the plastic is not completely connected, there is a break in the plastic. Just move the strap left/right a bit and you will see that you can unattach it there. Then you can unthread the loose end of the strap and completely remove the cover.
Credits for this go to my wife who figured it out after I already thought we should return the seat to the shop. :p
Posted on Jun 07, 2008
kezc
SOURCE: car seat cover
remove manual holder at back of seat. unhook harness from silver holder at back and pull through seat
Posted on Jun 16, 2008
Anonymous
SOURCE: Britax Car Seat First Class SI
i took the cover off the car seat and straps to wash the cover but have no clue how to put them back on.
Posted on Sep 27, 2008
Anonymous
  • 105 Answers
SOURCE: how do i remove maxi cosi car seat cover for washing please
hi bodsierpa..hope this helps..good luck!!!
• First remove the belt pads.
• Open the rim at the sun canopy as far as possible
• Remove the cover from the hooks
• Remove the cover then from under the hooks and quick adjuster button
• Pull the buckle tongue sections and adjustment strap through the openings.
Posted on May 16, 2009
Anonymous
SOURCE: harness straps off cosco car seat to wash cover, help reattaching
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
Posted on Sep 09, 2009
Hi I took the cover of to wash seating and I can't
Check your owners' manual or call the manufacturer.
Apr 17, 2013 • Baby Gear
Removing ferrari car seat cover to wash
Do not remove it unless you have the skills to remove the dozens of clips that hold the cover to the seat frame. BAD IDEA.
67helpful
Cant remove the cover off the straps at the bottom of the cabrio fix car seat i have removed it off the seat but can not remove the straps at the bottom to remove the cover
Had the same problem where you are left with the cover trapped by the quick adjust part for the shoulder straps located near the foot of the seat. The solution, the strap does detach at the front of the seat. The loop that is stiched round what feels like a solid plastic part of the base, turns out that there is a gap in the plastic so push the strap to either side and pull it out through the gap. With this removed you should now be able to remove the cover completly and bung it in the washing machine on a hand wash.
12helpful
How do i remove maxi cosi car seat cover for washing please
Need help rethreading safety strap
My son has special needs so I must wash his seat often. I can not remember how to put the straps locks back so...
First, whenever I wash the car seat cover, I rethread the straps immediately. I only unhook one at a time and look at the one that is still threaded to see how to re hook the one I am working on.
Since you can't do that at this point, I suggest going to a store that sells car seats, look at how the straps are hooked and if you have a picture phone - take a photo!
May 14, 2009 • Baby Gear
19helpful
Harness straps off cosco car seat to wash cover, help reattaching
1helpful
Washing car seat cover
Here are the download instructions for the seat. Page 49 has the instructions for removing the cover.
http://www.coscojuvenile.com/instructions/index.asp
Want to change the carseat cover to wash it
most of the car seat covers do have jip or under tied knots under the seats please do check in there and you can remove it for wash or change. check out for different seat covers in local dealers shop hope you will fine the best maching(color and texture) there. all d best.
Top Maxi-Cosi Baby Gear Experts
Marvin
Marvin
ray gallant
ADMIN Andrew
ADMIN Andrew
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
