Question about UTStarcom Blitz Cell Phone
Blitz Phone only works when charged
This happened this morning, everytime i plug the charger into my verizon blitz it comes on and says battery charging. I turn the phone on and it comes on when on the charger, and after two mins, it says low battery and shuts off, then its goes back to the charging screen and says charging complete then goes back to charging battery....how do I fix this?
Posted by mil4000 on
Anonymous
    New Friend:
The phones just a piece of **** mines doing the same thing and its not the battery the phone needs to be recalled
Posted on Feb 12, 2010
Anonymous
    New Friend:
You just need to get a replacement. i got this phone in september and this has happened eight times. if you have insurance on your phone you can get replacements, and make sure to complain. they offered me a nokia twist as a replacement if this happens again.
Posted on Feb 24, 2010
Anonymous
    New Friend:
I had my phone for a month and everytime i take off the batteries it shots off and i can only use it on the charger its really gettin on my nerves wat can i do
Posted on Feb 18, 2010
Anonymous
  • 283 Answers
Try a new battery if that doesnt work then there is a problem with the phone and you will need to have it replaced
Posted on Jan 28, 2010
I dropped it and now it won't turn on
it could also be loose wiring after you have dropped it, either way someone definitely needs to open it up and take a look
Apr 27, 2014 | Verizon Wireless PCD Blitz TXT8010 -...
My Verizon Blitz won't connect to my computer
Endless hours were spent trying to connect my Motorola Razr to my computer. This finally worked:
Go to Google Playstore on the phone. Download Motorola PIM (all upper case).
If you have an extended battery case/charger on the phone, remove the phone and insert the USB cable into the port on the top of the phone.
Or
Download "Airdroid" and connect wirelessly.
Nov 02, 2013 | Verizon Wireless PCD Blitz TXT8010 -...
I plugged in my phone but it will not charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 04, 2012 | Verizon Wireless PCD Blitz TXT8010 -...
My blitz keeps saying insert the battery when it already installe
the batteries dead. you need a new one because after the battery dies it wont awknowledge the charger or battery. same thing happened to me. honestly this phone is a piece of ****. youre gonna have a lot more problems ttrust me. im having a problem with it now.
Jun 30, 2010 | UTStarcom Blitz Cell Phone
My blitz phone battery isnt working AT ALL!!:(
i had the same prob my mom didn't believe me you have to push the charger in really hard still doesnt work all the time though
Feb 01, 2010 | UTStarcom Blitz Cell Phone
My verizon LG Blitz shut off today and will not come on. At first I thought it was the battery but even when I plugged the charger up it still won't come on.
my phone shut off. and it only comes on when it's on the charger.. and i even got a new battery for it, and it just does the same exact thing's... why is it doing that?
Oct 12, 2009 | UTStarcom Blitz Cell Phone
UTStarcom Blitz Cell Phone Logo
466 people viewed this question
Top UTStarcom Cell Phones Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Tafi Nami
Tafi Nami
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
