Question about SanDisk Sansa m200 (2 GB) MP3 Player
I am trying to delete songs on my playlist. I
I am trying to delete songs on my playlist. I keep trying to hold the select button to activate the "Add/delete" mode, yet nothing is happening. Can you please direct me to delete multiple songs? Thank you, StacyD
Posted by stacy_dorr on
Don Temp
    Sergeant:
    Champion:
  • 273 Answers
Connect your sansa to the computer and via usb cord check computer the hardrive letter e,f,d, whatever right click that letter and then format. this will delete all the songs. or you could open windows media player click sync and then drag and drop songs from your computer to your sansa or visa versa.
Posted on Jan 28, 2010
How do i delete all my songs on my ipod?
Hi inthebag pik...
Try this easy way to delete your unwanted songs...
Deleting Files,Pictures,Videos,Audio Books, Apps,etc. from MP3 Player/Ipod
BIG WARNING: DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
ONE MORE BIG WARNING: BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Please take time to rate me thumbs up
Sep 17, 2011 | Apple iPod nano 5th Generation
I can't make my archos
be sure that you have already saved a list of song on your playlist. and for the pdf also make sure that there was a file that save on that location...
let me know
Aug 29, 2008 | Archos Audio Players & Recorders
How do i delete playlists that i have created. I have managed to delete the music but can't seem to beable to remove the playlist title .eg.playlist0000 and playlist0001 and so on . Ihave created...
Hi barrieleslie...
Try this way
This is a FREE answer, Please take time to rate me
May 28, 2011 | Archos 605 Wifi Portable Multimedia Player
I have a slick 4gb mp418c-4. i have been trying to make use of the playlist files but can't seem to get it. how do i create playlists in my files?
How to make a Playlist --- Listen to the song you want to add to a Playlist. While the song is playing, press & HOLD the [MENU] button for a couple of seconds. Another screen will appear with the following options. 1. Music Playback -- Normal / Random 2. Select EQ 3. Lyric Display -- Enable / Off 4. Add to MyList 5. Delete the File Move to #4 and press the [SELECT] button. Playlists will appear. Choose which one you want to add songs to and press the [SELECT] button. A check-mark will appear, meaning song has been added to PlayList. Press [MENU] button to get out. To DELETE songs from PlayList --- Go to options list when you first enter Music file and scroll down to 'My Music List'. Press [SELECT] button, Highlight the PlayList you want to delete songs from and press [SELECT] button. Highlight the song you want to delete, press and HOLD the [MENU] button for the delete screen to appear. 2 options on that screen - OK & Cancel Hope this helps Andrew
Apr 29, 2011 | Audio Players & Recorders
Deleting songs , how do you delete songs off the ipod touch?
connect it to itunes.. click on the ipod and under the music tab.. uncheck sync all music from music library
Dec 22, 2009 | Apple iPod touch
How can i delet a song from iphone
If you want to delete music from iPhone, you can take fully advantage of iTunes. After you purchased songs in iTunes Store on iPhone, your iTunes will also save the purchase history, so you don't have to worry about losing the purchased music files. When you connect iPhone to computer with USB cable, iTunes will launch automatically and recognize your iPhone. You can create a new playlist which contains only the music you need, and then sync it to your iPhone. By doing this, you can remove the unwanted music from iPhone.
  1. Click the iPhone icon at the upper left corner.
  2. Choose Music in the left sidebar.
  3. Check Sync Music choose Selected playlists, artists, albums and genres.
  4. Select the playlist which only contains the songs you need. Then click Sync.
delet-song-from-iphone-oxaxc0rwhkhzilrwacqreyis-5-0.jpg http://www.leawo.org/tutorial/how-to-delete-multiple-songs-from-iphone.html
Oct 21, 2009 | Apple iPhone 3G
Hi!i cannot put a songs to my zen v plus...what will i do?
What you should do is to go to all tracks and play one so that it is in the 'now playing' section. Then, hold the return buttontil the menu appears. go on remove (this only removes from the playlist, not delete the file! trust me). then remove all. next, go back to the all tracks and hole return on the track you want to add to the playlist. Go down to 'add to selected'and it is in. (it will automatically select the next song so dont keep pressing it...you should see the selection in the background move down). Do this for all the tracks u want. Go to now playing and hold return, then 'save playlist as', and save as the file. Then it can be accessed through the playlists menu. Hope this helps poeple!
Apr 13, 2009 | Creative Labs ZEN V Plus MP3 Player
Cant delete songs off my ipod
Two possible solutions:
Solution 1. Go to iTunes, go to Edit, Select All, go to Edit once again, select Delete. This will clear your whole music library. Connect you iPod and let it sync. It will delete everything in your iPod. The problem with this is that it will delete all your music in iTunes as well so you better back it up elsewhere.
Solution 2. Go to iTunes, connect your iPod, let it sync. Do not disconnect your iPod. On the left hand side of the screen you will see "Library", "Store", "Devices", etc. Go to "Devices" and you will see your iPod's name there. Click on it and you will see on the right hand side of your screen your iPod, with some menus tabs. On the first tab (Summary), make sure that "Sync only checked songs" is activated. Then go to the second tab ("Music"). Make sure "Sync music" is activated and "Selected playlists" is also activated. Make sure NONE of the playlists is activated. At the bottom right hand side of the scree there is a button that says "Sync". Press it and it will sync no songs into your iPod. That should clear the songs but leave the contents in iTunes intact. If you want to put some playlists in your iPod, then check only those and only those will be added to your iPod.
Hope this helps.
Jan 01, 2009 | Apple iPod nano MP3 Player
How to delete to go playlist
Open the 'Playlist on the go' and scroll to the last in the songs list. There u will find an option 'Clear Playlist....
From there you can delete the Songs from Go Playlist
Apr 13, 2008 | Audio Players & Recorders
We have a RCA H115A
Go through your list of songs loaded into your player. Highlight the song(s) that you want added to create a different playlist and hold the toggle down until you see "added to my Selections" (or something like that). Once you have selected your songs, go into the main page (titles, artists, albums, etc.) and select "playlists". You should see an option called my Selections/Favourites. Highlight and push the "menu" (m) button. Select Save playlist and name using the toggle up and down for each letter and over to work on the next one. Once you have saved and named the playlist. Return to my Selections/Favourites and delete to clear the list. Now you can create a new playlist....Now I just gotta figure out how to fix the System file corrupted problem on mine.
Nov 15, 2007 | Audio Players & Recorders
SanDisk Sansa m200 (2 GB) MP3 Player Logo
110 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Jean Sintulaire
Muntejaya Ginting
Muntejaya Ginting
Daniel Dollive
Daniel Dollive
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
