Whirlpool Calypso GVW9959K Top Load Washer Logo
Posted on Feb 05, 2018
Whirlpool calypso gvw9959kq2: Q-the washer stopped and gives no code. the display reads 44 (as in minutes) and the displays are lit up as if a load were going to be done. when i press cancel i just beeps and the display is the same. i unplugged it and when i plugged it back in it was the same.
George Lawrence
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Feb 05, 2018
George Lawrence
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
5930
Points
44
Sounds like something is stuck in the drain motor
5 Related Answers
Anonymous
  • 5911 Answers
  • Posted on Apr 29, 2007
SOURCE: washer displays DL error
The FdL fault is a door lock error code. It sounds like you may have a bad door latch. Unplugging it and/or pushing the cancel button will not clear the fault as long as the fault condition exists. At best, you may have to replace the door latch. At worst, the CCU (main computer) could also be bad, causing the fault. The door latch can run about $50. The CCU is about $200. Double check all you wiring first before replacing any parts. I hope this will help you.
Anonymous
  • 5911 Answers
  • Posted on Jul 24, 2008
SOURCE: whirlpool calypso clothes washer stuck
Try pressing the following key pad buttons within 5 seconds - PREWASH OPTIONS - WASH TIME, PREWASH OPTIONS - WASH TIME, in this sequence and allow the washer to run. The LED display will start counting down as the washer begins a sequence of short diagnostics tests. If no error is present, the washer will return to standby. If the error persists, you may have a blockage in your drain pump. Please run the test and let me know the results. Total test time is about 1 minute 40 seconds. I hope this helps you.
Anonymous
  • 6966 Answers
  • Posted on Sep 05, 2008
SOURCE: WASHER WON'T START
For some unknown reason(s) the Live Session/Chat window closed. I hope that the two buttons resolve the issue, otherwise, pls click on "Ask Me" for a follow-up solution.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Anonymous
  • 294 Answers
  • Posted on Apr 06, 2009
SOURCE: Whirlpool Cabrio Washer Error message code F1
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
Anonymous
  • 351 Answers
  • Posted on May 08, 2009
SOURCE: CA error code on Calypso Washer
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Meaning you had stuffed it full one time and then it was hard on the motor, you will have to change the drive motor most likely...
1helpful
My calypso GVW9959KQ2 displays L5
its probably LS not L5 code,which is a lid switch failure and this will result in a machine that will fill and possibly agitate,but wont spin out.replace lid safety switch located underneath top of units outer case
1helpful
Where can I get a User/Owners Manual for Whirlpool Washer, Calypso Model # GVW9959KQ2
My buddy Robert and me got into a couple of these washers; an older one and a newer one. I took some photos and included your manual HERE and HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
My whirlpool calypso washer just quit working no codes no power just dead. GVW9959KQ2
Won't Power Up
  • 120VAC electrical supply.
Check voltage supply to washer.
  • Open AC cord.
Check for voltage at the power cord connection to the line filter.
  • Line filter open.
Check voltage into and out of line filter.
  • Machine control board open.
With the washer off but connected to the AC outlet, measure the AC voltage between Pins 4 and 2 at connector P16.
I have a Whirlpool Calypso washing machine, model
communication error. changing the MCU. sometimes a bad pump could be the problem
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
1helpful
Whirlpool Calypso Mod: GVW9959KQ2, stops and shows "ob" as code for fast final spin. Also making high pitched whine during wash cycle. Appl svce place has suggested bearing or xmission. Any possible...
Sorry to say but they are right. The Calypso washer was a horible design given to whirlpool from maytag. I would suggest you go buy new machine. Buy someting that looks simple and easy to use. The more complicated the unit the more problems you will have down the road.
Beeping and Frozen, 44 min
If it is a Calypso, abandon it immediately... it is amazing you still have it. One of the worst designs, ever. Whirlpool Washing Machine Drain Pump 285990 No Longer Available
Whirlpool Calypso
This could be an out of balance condition. When its happened to my washer, I rearrange the load if its large enough, and if its not, I find other items of like weight and add them to the load and start over. Calypso's are sensitive to fabric weight, so If you're washing towels, wash only towels and wash cloths. Make sure you put small items, like bras, panties, nighties, etc., in mesh bags and combine them with other light weight fabrics.
2answers
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
