Texas Instruments TI-83 Plus Calculator Logo
Posted on Jan 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I accidentally deleted they y column from my
I accidentally deleted the "y" column from my table. Is there any way to restore it?
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on Jan 28, 2010
k24674
Level 3:
Answers
8093
Questions
0
Helped
4671997
Points
21595
If that Y-Column was created by a function (Y1=...) recreate the table by pressing [2nd][GRAPH] (TABLE).
If the column is a list of statistical data that you entered, there is no way to restore it. Just reenter the data anew.
My Y table got deleted. When I click 2nd graph I see the x table but the next column is empty I need my Y column.
You need to define a function before you get anything in the ytable. The x-value are there by default.
tip
Deleting Rows & Columns from the table
You can also remove columns or rows from the table. Once a row or column is deleted, it can be undeleted by using Undo command. You can delete the columns or rows or cells by using one of the following ways.
By Table Menu
To delete a row or column by Table menu, follow these steps.
  • Place the insertion point in the column or row that is to be deleted.
  • Click Table menu and then select "Delete" from Table menu, a submenu of Delete is displayed.
  • Select Columns or Rows or Cells command to delete the selected element (column or row or cell) from the table.
By Popup Menu
To delete a row or column by popup menu, follow these steps.
  • Select the column's you want to delete.
  • Right click the mouse, a popup menu is displayed.
  • Select "Delete Columns" command, the selected columns will be deleted.
OR
  • Select "Delete Cells" command, "Delete Cells" dialog box is appeared.
  • Select "Delete entire row" to delete a row or select "Delete entire column" to delete a column etc. from the dialog box and click "Ok" button.
on Jan 29, 2010 • Computers & Internet
1helpful
2answers
3helpful
2answers
Can I restore photos that were deleted from camera in error
Hello friend,
Yes, you can easily restore accidentally deleted photos from camera memory card with the help of photo recovery tool. Some days back, when I was stuck under similar situation where in I had accidentally deleted all my pictures from camera memory card. Then I tried this tool which really helped me to restore all of my deleted photos from memory card. Just click here if you want to try this software.
Best of luck,
Entyn Fernandis
3helpful
I went to my table the other day, and accidentally deleted the Y column, do you know what I can do to get it back? thanks for your time.
The table corresponds to the values of a certain function you entered through the Y= Editor. Reenter the function as Y1= and the Y column will be regenerated.
If you are dealing with paired data ( statistical values) enter one variable in list L1 and the other in List L2 and use the statistical feature to draw a scatter plot or perform other data processing.
1helpful
I want to enter in numbers for L1 and L2, but when I go the TABLE there is no L1 or L2 column, only X, and there are numbers entered in the X column that I want to delete. How do I clear the X values,...
The table is where the calculator displays values from functions entered in the Y= page. To enter numbers into lists, press STAT and select Edit to get into the list editor.
4answers
HOW TO SOLVE VFP FILE CURRUPT WHEN POWER FAILURE
At times, you may view that your MS Visual FoxPro 9.0 database is behaving abnormally. Some of the abnormal symptoms could be an error message while opening any database table, invalid characters in place of pre-defined values, and and more. The main reason for abnormal behavior of the database is its corruption due some logical crash. Few common reasons for corruption of MS Visual FoxPro 9.0 database are abnormal termination, faulty network devices, simultaneous modifications, conflicting third-party software, and incompatible service packs.
To overcome such database corruption scenarios, the user can use an up-to-date backup and perform restoration. However, restoration fails in cases where the user either forgets to create a database or the database backup itself gets damaged. In such cases, the database users can use a third-party DBF File Repair application to repair his/her corrupted database.
To illustrate the above case, consider a real-time scenario wherein you execute a query to modify your MS Visual FoxPro 9.0 database. While the query was performing the modification, the system shutdown due to power failure. However, the next time you tried to mount the database, you encountered an error message that did not allow you to access the database records. Moreover, the same error message appears every time you try to access the database.
Cause:
The root cause for the error message is MS Visual FoxPro 9.0 database corruption due to improper system shutdown.
Resolution:
The database corruption error message can be surmounted by following the below steps:
Use a complete database backup and perform restoration. However, in case of database backup unavailability, you will need to search for a commercial DBF File Repair utility.
A third-party DBF Repair application uses effective repair techniques to repair logically damaged MS Visual FoxPro 9.0 database and restore it at a new and safe location. The original database during the repair process remains intact. The tool is easy-to-understand and allows even a non-technical person to perform repair.
DBF Recovery Software is a comprehensive solution to repair databases created in MS Visual FoxPro 9.0, MS Visual FoxPro 8.0, and MS Visual FoxPro 7.0. The tool also repairs databases built in dBase III, dBase IV, and dBase V. Supported by Windows 7, Vista, 2003, XP, and 2000, the DBF Repair tool creates a new repaired file that can be attached to existing database.
Tanvi Sharma is a self employed Internet entrepreneur and product reviewer. This DBF Repair utility is extremely useful when the dBase and Foxpro database gets corrupted due to internal program errors, hardware malfunctioning, accidental deletion of data and more. This DBF Repair software repairs all types of database components including table name, column name, column data type, indexes and primary keys.
5helpful
Deleted y column in TABLE
I do not think that you can DELETE it, you probably just cleared the equation, just put another equation into Y=, and it will work.
otherwise, if you don't have any programs you need or so... just press 2nd +
Scroll down to reset, and press clear RAM
15helpful
7answers
Undelete records from access table
ou can try to use third party Access recovery utility to restore your lost and damaged data from .mdb files. For more details about this software:-
Access File Recovery
To delete a column from a table working /as sysdba
If your password is setup for admin, you should be able to bring up the table structure and delete the field. You may need to disable SQL server to do this if your table is opened on another computer.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
