Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Problem with spin in rinse cycle
Whirlpool ultimatecare II top load washing machinenspins in wash cycle but in rinse cycle after agitation, spin won't start unless I open then close lid. Spins starts evert time right after I open and close lid. I replaced motor coupling, which had a little wear, but that did nothing. Could the lid switch be the problem?
Thanks.
Posted by eric_olsson on
Dan Webster
  • Whirlpool Master
  • 8,221 Answers
Yeah that is a lid switch problem. I have a page I compiled that shows how to fix this easily: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 28, 2010
Whirlpool washing machine top loader will not rinse or do final spin
If your machine fills and agitates through the wash cycle and then stops, check the lid switch.
http://www.youtube.com/watch?v=bV8C6aLBL9w
Mar 03, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
Mar 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
sounds like a broken coupling.
it probably don't agitate either.
Oct 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
