Yamaha YST-MS201 Computer Speakers Logo
Anonymous Posted on Jan 28, 2010
The problem I have is that suddenly the right speaker and the buffer doesn?t sound any more. I disassemble the right speaker and test it with another system and it works. What do you recommend to do. Thanks
  • 1 more comment
  • Anonymous Jan 28, 2010
    I have checked with more volume and the buffer and the right speaker have very low sound, which is telling me that both are Ok.
    Is this new situation gives you more information for a more secure veredict ?
    None of the possible solutions is acceptable because you are forgetting that the problem is not just for one unit the problem is for both the right speaker and the buffer. Both have the same problem. ONLY the left speaker works perfect.
    The system in the picture above has 3 units 2 speakers and the buffer.
Anonymous
Level 3:
  • Master 542 Answers
  • Posted on Jan 29, 2010
Anonymous
Master
Level 3:
Answers
542
Questions
0
Helped
87591
Points
1651
Check and adjust the sound balance in sound properties will resolve your problem.
Revert back for more assistance.
Ginko
Level 3:
  • Yamaha Master 19,396 Answers
  • Posted on Jan 28, 2010
Ginko
Yamaha Master
Level 3:
Answers
19396
Questions
25
Helped
8073372
Points
55462
Hi.
Ensure that you have already disconnected the unit from power for ten minutes. Ensure that the problem is not the source, or connector to input source, that is common cause of this problem.
Check well the speaker connection. if you have no sound on one channel, then the amp is faulty.
You may have blown the amp final right channel. I do not know if this system uses amps or ICs.
Soldering joints to speaker wiring and components must be tested.
In any case, if the problem is not the speaker or the cable, there is an internal failure, and the unit must be disassembled and tested at component level.
try calling Yamaha at the number listed on the manual and see what cover they can offer for this problem.
  • 1 more comment
  • Ginko
    Ginko Jan 28, 2010
    Here also a service manual with schematics:
    POWERED MULTIMEDIA SPEAKERS
  • Ginko
    Ginko Jan 28, 2010
    What has probably blown is that upc4570ha in the picture below, taken from page 6 in service manual.
    That is a dual low noise amplifier built by Nec. Test for continuity those couple of resistors, eventually replace the capacitor, usually you need to replace the chip if any of them had blown.
    For safety reasons all testing and repair must be done by trained personal.
  • Ginko
    Ginko Feb 01, 2010
    Well, I gave the service manual for free, and the big speaker is called Woofer, not Buffer. If you told us before leaving bad feedback, I could have helped more.
    Now that you have received your refund, please change the negative rating given!!
    That is only bad for us that have wasted our free time and effort trying to help you.
    Goodbye and thanks.
    G.
Logitech z-506 computer speakers not working
Have you got the 3.5 mm plug in the sound out it could be in the mic hole.
No Sound At all from the Speakers. I have plugged and replugged in the connections. I am getting power but absolutely nothing out of the speakers. Some minor static if I wiggle the power cord,...
no sound at all it was working fine before i got additional speakers creative sarrounding withe 2 mini and 1 sub buffer how to test it its just not comming on now
2answers
Yamaha RX-V365 Receiver, Yamaha NS-AP2600S(BL) Speakers
Make sure the speaker select switch is on "A or B or AB. It's a small button on the front panel of the receiver (pen sized) and will give you visual feedback on the LCD display. If they are on, you need to have the unit bench tested at an audio shop and possibly repaired. Hope this helps
My rear and center speakers suddenly quit working. No sound
try a different source. if there is output on all speakers in test mode, then the amps are good but the source or source switching may have a problem.
No sound from front right and left speakers
you may have a dc condition present on speaker outputs. this could be caused by dry solder joints, suggest blanket resolder of the output stages for front channels.
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
Both left and right speakers play audio for right speaker
I think you mean the left channel is out but when you use test tone, the sound comes from left and right channels through the right channel speaker. If this is case, the switching IC is malfuncting. Unit needs service
No sound from Front Speaker
take amp to a workbench, have a test speaker in hand, touch the speaker wires to each channel to see if all channels work. take each speaker to the amp and temporarily hook one at a time to see if any speaker is bad. if you eliminate the hardware, you know it's the wires in between.
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
