Microsoft Windows Vista Business Edition for PC Logo
Posted on Jan 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just bought an new Windows Vista machine. Have
Just bought an new Windows Vista machine. Have "I Want TO Read" for Windows 95. It installs on Vista but will not run. Complains about the audio software not being correctly installed.
electronic & computer repair& servicre
Level 3:
  • Microsoft Master 12,061 Answers
  • Posted on Jan 28, 2010
Microsoft Master
Level 3:
Answers
12061
Questions
0
Helped
4007807
Points
36390
You must set this program to install and run in "Compatibility Mode" for windows 95.
Right click on the installer setup exe and choose run in compatibility mode and check for Win '95. Do the same for the main EXE of the program too, also make sure you run BOTH as "Administrator"
Running qbert on a windows vista crashes
Consider that perhaps that program is not compatible with your current computer/OS/video card, etc.
Happens.
I am looking to set up an old computer with new memory and hard drive. I have windows vista from my laptop computer can I install this into my newly updated computer and how.
Generally, the licensed software for your laptop is tied to that machine/brand. If you bought a copy of vista and installed it on the laptop, you may be able to install vista on three machines if that is the version you bought.
Most Microsoft programs are locked to one machine and won't activate on another system.
Now, if this is an old, slow (less than 1 Ghz) with less than 2 gigs, it probably will run Vista very slowly if you get it installed. I'd use the OS that was on the old machine instead of trying to install Vista.
I get a report message saying basically this : An Error occured during installation.The driver installation files for this device is missing a necessary entry. This may be because the INF was written for...
Yes,
 you need a Vista driver for this device, windows 95 shows how old it is !
If you are upgrading from WIndows XP to Vista delete all the mouse drivers in the device manager (under control panel).
Then let Vista install new ones.
2answers
I am looking for a monitor driver for Windows Vista for LT1919
Windows XP and Vista should "auto-detect" the capabilities of this LCD screen.
If not, access http://WindowsUpdate.Microsoft.com
and scan for updates.
When the scan is done, look for "optional hardware" updates.
If Microsoft has a driver, it will be offered for download.
Steering is sticking will not turn by it self
Microsoft Windows 95 is no longer supported by Microsoft.
Upgrade to Windows XP, or buy a new computer with Windows Vista pre-installed (and with a coupon for Windows 7).
Get your 95 FORD EXPLORER towed to a certified mechanic; it is *NOT* safe to drive the vehicle.
1helpful
Vista
Unfortunately, one of Microsoft's less popular concepts when releasing Vista is the fact that Vista has no backwards compatability for programs or hardware. You will not be able to install those programs as long as you have Vista in your computer.
1helpful
Vista will not work with autostar 494
I did some research on meade 506 astrofinder software
Read this...
Customer Review:
Rating: stars-1.0.gif
Summary: outdated software
The software this kit comes with is old and outdated. It is not supported by Windows XP nor Windows Vista. The latest supported version of Windows is Windows 98.
It also appears that the included software is a limited trial software. It is limited to the included 3 catalogs (star maps). The complete set of catalogs must be purchased additionally at quite some expense.
The cable connection kit couldn't be reviewed because it was missing from the package I received, but keep in mind when you order this kit, that neither Windows XP nor Windows Vista support serial ports anymore. The additional USB to serial adapter would be required.
That last line would suggest to me that if one had a USB to Serial adapter it might work? but I really do not know for sure. checking into some more stuff...
Found another article that states "It requires a PC running Windows 98SE through Windows XP. It will not run under Windows 95 or earlier, nor will it run under Windows Vista."
OK I found this site, you might be able to make some sense of it. But I did read in there that they do make USB serial adapters that will work with Vista OS.
Good Luck and happy star gazing! If you find something new out there maybe you could name it after me if you get it working. lol
How to let Learn to Speak German 8.0 run on Windows Vista
unfortunately there is no way around it as the software is not compatible with vista and wasn't designed for vista, i had a similar old software installed fine with vista but this is not true for most of them
sorry
Windows Vista problem
There are Vista drivers at this site: download and install - works fine.
http://www.kodak.com/global/en/service/software/easyshare/en/dln_ekn026079.jhtml?pq-path=4509
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
