Question about Zenith C13A02D 13" TV
Need remote code for zenith tv model c13a02d - Zenith C13A02D 13" TV
Posted by durham appliance on
  • durham appliance Jan 28, 2010
    The manufacturer normally has one specific code per model. The range of codes you listed are for the general models of the manufacturer, but there are specific codes...sometimes listed in the manual but usually hard to find. After i posted the question I decided to use another remote, Logitech Harmony 880. With that remote, I connect it to my computer, access the website for the remote, put in the model of the item i want to control. The website requires the model number as it has model specific codes,. If it cannot find the model number it suggests one that is similar or you have to follow a search procedure using the recognized codes for the company. I have two of those remotes and they have found every model i threw at it.so far. The remote then works instantly on the devices without having to scan through codes. Only problem is I have yet to find a way to reveal the code that the software/website found and I don't want to continually use this remote for tv since the tv is located in a seldom used room and those remotes are expensive. I have other decent universal remotes that I want to use. Tried using the suggested codes for zenith to no avail and tried scanning. Maybe the remote I want to use has a Learn feature and can learn from my logitech or maybe I just have to press the scan button another 200 times or so. I'll give both of those a try. Thanks for your quick response.
Marvin
    Top Expert:
  • Zenith Master
  • 85,239 Answers
Remote code don't go by model, you get a list of codes and you just try them one at a time until one works, here are the most up to date remote codes for a Zenith TV.here are the three digit codes
101, 142, 149, 177, 241, 345.
remember all universal remotes have code search, so if none of these seem to work do the code search function, it is outlined in the user manual of your remote.
Posted on Jan 28, 2010
  • Marvin
    Marvin Jan 28, 2010
    I am aware models have SPECIFIC CODES, but they are not published, just code lists I have more 4 digit codes listed for my remote..
Get into the menu of the tv with out original remote
Try a universal Remote they are $9.00 at walgreen's
Oct 27, 2012 | Zenith C13A02D 13" TV
Zenith tv. #model b19a23dc need new remote
Try website like Remotes.com to buy the tv original remote or a very close compatible one.
Aug 31, 2011 | Zenith C13A02D 13" TV
I need the Zenith remote control code for the 1986 Zenith TV
joe, the remote control codes are not the same from vendor to vendor. I think you're trying to program a universal remote control to operate your tv, if this is so, you will need to get the model number of the universal set and refer to the product code list, look under tv and zenith, another procedure you may try is the code search, this puts out all the available codes programmed into the universal set, just follow the instructions and be very patient because like I mentioned it will take you through all the available codes untill it will send the correct one for your zenith tv.
Feb 10, 2010 | Televison & Video
Need remote code for Zenith tv model no tvbr1942z
I got code 21479 to control power and channel up/down but it won't manage volume. That code also pulls up the menu for the TV too. Could not determine VCR compatibility since the VCR died ages ago.
Sep 22, 2009 | Zenith TVBR1924 19 in. Combo
Remote control(s) suddenly will not operate any function.
How do you KNOW the controller is Good??
There is a little Infra-red receiver behine that little glass window on the front of your TV. This has been known to go bad (assuming all those things are good that you said are good!)
Aug 18, 2009 | Zenith C13A02D 13" TV
One for all remote tv code
Go to the link below. Select the model that you have then select TV then select Zenith then click on Submit
http://www.ofausa.com/en/advanced_search.php
Oct 26, 2008 | One For All URC-4330 Remote Control
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
Zenith C13A02D v-chip disable
here is the link for the user manuals from zenith - they dont have one for your exact model, but if you type in C13A03D you will get a manual - page 34 details all the v-chip settings and should be nearly identical to your model at least; http://www.zenithservice.com/gcsc/b2c/hpi/main?tc=owm.command.OwmCmd Hope this helps - please post again if not :)
Apr 18, 2007 | Zenith C13A02D 13" TV
Zenith ZN-501S remote control codes and instructions
From the ZN5015 code manual for Quasar TV 007 107 416 608 618 718 807 901
Apr 15, 2007 | Zenith ZN-501S Remote Control
Zenith C13A02D 13" TV Logo
231 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
