Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
You have hard drive issues or windows files are corrupted, remove hardware and reseat it back in place, sometimes this will get the hard drive working, if this fails! set the boot order to DVD CD and try and run the recovery disc, if no change! it means the hard drive has issues and may have to be replaced.
Check if your hard rive indicator light is flashing (has disc shape icon or can shape icon next to it). If it is then put in your windows disc and do a startup repair. Make sure it is booting from the disc drive first. if it isnt flashing then you may have a dead hard drive. Try taking the hard drive out and putting it back in.
hi there,
in this case you mention that it check then system configuration and then goes blank,so therefor your windows XP installer is corrupted replace your windows installer.regards and have a nice day don't forget to rate me.
Try to check connections to hard drive...If OK..then check boot device priority in BIOS and change 1st boot device as Hard drive..Then If not worked then chnage 1st boot device as cd rom and boot from a bootable CD and installl OS..
