Question about Hauppauge WinTV-HVR-1250 MC - White Box (DHHAUP1187CN) TV Input
Dell? Hauppauge WinTV-HVR-1250 TV Tuner "IR Hardware not detected" message during setup
Posted by fghdghd on
Bblaster
    New Friend:
  • 92 Answers
Make sure you have the remote sensor plugged all the way into the connector on the card. Also check your taskbar for the "remote" icon which confirms you have "irblaster32.exe" installed.
Posted on Feb 07, 2010
I have a HP Media Center PC 470n. Is there another card just for that PC. I have the wintv- hvr 1600,not as happy as I thought I would be.
You can use any capture card you want as long as you have a slot on the mother board. Media Center works with almost every capture card.
Having said that, i found hauppauge a great capture device what was it you didnt like?
Xp media center says no ntsc tuner installed
Okay, Media center does not work with some Wintv HVR's yet it will work with the software it came with and sometimes media center will use the wintv software to make it work but its sketchy. If you want a more media center compatiable card look at www.microsoft.com website they have a list of media center compatable Tv tuner cards, Trust me I am having the same problem with my tuner card now and its not wintv its a RCA and its under windows 7 this is just the thing here not all card work with media center.
Thanks for using fixya.com please do click the accept button.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Windows media center can not find ir receiver
be sure you have installed the driver. If you are using windows 7 you still need to install the winTV driver. I know this because I had the same problem. It should work then. Just go to TV setting in the media center setup and it should scan for channels.
1helpful
Tv tuner
Basically what I can see from what I have read one had dual tuner capability and one is set up for PCI Express. Both look like great cards.
http://www.hauppauge.com/site/products/data_hvr1600.html
http://www.hauppauge.com/site/products/data_hvr1800.html
Thanks
Armymason
No Audio with WinTV-HVR-1600 when tuning on S-Video
okay after more reading I found I needed to hook up the A/V output on my camcorder to my line-in input on the capture card (WinTV-hvr-1600) and now audio is working!
WinTV-HVR-1600 Tuner card to DishNetwork receiver
Yes, but what it can connect to depends on what Dish DVR you have. The newer, HD ones only have HDMI, S-Video, and that 5-split coax as outputs for the main TV since you only get these box's if you have and HDTV.
This is because regular old coaxial is no longer good enough for them. This means you must connect the newer DVR's to the S-Video input on the Hauppauge1600 since it is the only input to the card the Dish DVR supports.
If your DVR is older and has the coax out, you can use that and connect it to the Hauppauge analog input.
Hauppauge WinTV HVR-1600 - ATSC HDTV receiver
I have a Hauppauge WinTV HVR-1600. I have a comcast digital box hooked up to my PC. Signal is bad and black and white media. I installed the "current" driver two weeks ago (mid October) Work great! We had to perform a PC recovery. I downloaded the "current" driver. Got weak signal and black and white only.
2answers
TV Tuner for my HP
Hello Matt,
WISH YOU HAPPY MERRY CHIRSTMAS!!!!!!!!
I am Vikram Kumar Thumu from India- Hyderabad. I have seen your message on the issue related to the Tv Tuner card. Since, I work with HP as Technical Support I would like to suggest you on this issue.
Well, the "HP ExpressCard TV Tuner for Windows Vista
(RM436AA#ABA)" supports only for Windows Vista.... and it will not work with Windows XP.
If you are lookng for Windows XP Tv Tuner Card, I recommend you to purchase Hauppauge WinTV-PVR USB2 (EC557AA#ABA). As this one supports for Windows XP but needs Microsoft Windows XP Media Center Edition 2005 .
These are available solution for you at this moment . I hope that this should resolve the issue for you.
If you need any other information please do mail me at [email protected]. I'll be glad to help you.
Once again WISH YOU HAPPY MERRY CHRISTMAS!!!!!!!!!!
Thanks,
Bye...
Hauppauge WinTV-HVR-1250 MC - White Box (DHHAUP1187CN) TV Input Logo
Top Hauppauge Televison & Video Experts
Ekse
Are you a Hauppauge Televison and Video Expert? Answer questions, earn points and help others
