Question about Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker
Subwoofer and amplifier wattage problem
If I have a subwoofer with an RMS of 500 watts and peak power of 1500 watts, and I use an amplifier with an RMS of 300 watts and a peak power of 1100 watts, will this affect the functioning of the subwoofer or it's quality?
Anonymous
    New Friend:
    Problem Solver:
  • 6 Answers
No it will sound good if you can put an amplifier with 500 watts rms it will sound better
Posted on Jan 30, 2010
Two questions. 1) can my amplifier over-power this sub; kicker L7 15 inch dual voice coil 1,000 watts RMS wired for 2 ohms? 2) is my amp too small for this sub-woofer? thank you for your time.
No, your not over powering your L7, your underpowering your subwoofer.
Your Kenwood is
500W x 1 at 4ohms [20-200kHz 0.5% THD]
900W x 1 at 2ohms [100Hz 1.1% THD]
Your L7 is:
Max Rec Amplifier Power (WATTS PEAK/RMS)* 2000/1000But its ok for your subwoofer, alteast your not giving it to much stress. But personaly, get another mono amplifier that would match your subwoofers rating.
1helpful
I need to know if the specifications for the Perfomance Teknique ICBM-5712DX RMS total wattage is for both coils or per coil. The RMS total wattage rating is 500 watt
The 500W RMS total wattage is for both coils combined. If you want to get REALLY specific, all of the industry-specific specifications are as follows.
  • 12" Dual 4 Ohm Peformance Subwoofer
  • Power Handling:
    • Peak: 1000 watts
    • RMS: 500 watts
  • Impedance: Dual 4 ohm
  • Reinforced aluminum curvilinear cone woofer
  • Oversized butyl rubber surround
  • 5 spoke Die-cast aluminum basket
  • 2" Flat ultra excursion spider
  • Industrial Chromed Hex bolt retained T-Yoke
  • DC resistance (Re): 3.2 ohms each coil
  • Frequency range: 20 Hz-1.1 kHz
  • Fs:30 Hz
  • QTS:.526
  • QES:.614
  • QMS:7.698
  • VAS:56L
  • SD:.0491M
  • SPL: 89.58 dB 1W/1m
  • Xmax:16mm
  • Mounting Depth: 160 MM
  • Mounting Hole Dia.:282 MM
  • 0helpful
    What size amp needed with a sony explod player?
    this bandpass enclosure is rated peak power at 1200 watts . what this means is that each subwoofer in the is peaked at 600watts to make 1200 watts . what your looking for is to power up the subs with rms continuous wattage . you need an amp that will put out 400 to 500 rms a channel to run this sub enclosure at 800 to 1000 watts rms to keep the speaker from blowing
    audiopipe apf1801
    71671968.jpg this amp will give you 1 channel @ 4 ohm x1 350 watts 1 channel @ 2 ohm x1 900 wats 1 channel @ 1 ohm x1 1800 watts you would have extra power for better subs with more power later but you get 900 watts which when connected right would mean 450 watts per sub be perfect for you . i sell this for $320.99 in my store can shipp any where in usa to contact me [email protected]
    1helpful
    I hooked up 2channel 500 watt amplifer and 1200 watt 300 rms subwoofer now the protection light comes on when i turn up volume
    your speakers rating is too low for your amplifier. 300 watts RMS means the speaker can operate on an average of 300 Watts continuously. the 1200 watt rating is peak wattage input and meant for intermittent intervals only, a like a bass drum beat count. also , your speaker impedance must match your amplifier impedance or the speaker must be a higher impedance than the amplifier. Never lower than the amplifier's impedance output rating. If The amplifier is rated into an 8 ohm load, your speaker must be 8 ohms or higher. in other words you cannot use a 4 ohm speaker or you will damage the amplifier .
    7helpful
    2answers
    What wattage amp do I need to get good sound in a toyota corolla
    Make sure it's a RMS 1200 wats not MAX watts also the Ohms of this speakers and them you can buy any amp. with the same RMS watts of your speaker and same Ohms of resistance.
    I have 2 15 inch mofos do i need two poweracoustik 4000D AMPS?
    You want an amplifier that is rated for the subwoofers. In your case your subwoofers are rated at 1500 watts rms each, so you will need an amplifier of 1500 watts rms or more for one subwoofer. good luck
    2helpful
    What is the rms and voicecoil configureation on these the older aw1200
    here is all the specs for your sub
    12" subwoofer with two 4-ohm voice coils
    » carbon composite cone with foam surround
    » heavy-duty cast-aluminum basket
    » power range: 50-700 RMS watts (350 watts per voice coil)
    » peak power: 1400 watts
    » frequency response: 20-500 Hz
    » sensitivity: 94.65 dB
    » mounting depth: 5-5/8"
    » sealed box volume: 0.50-1.50 cu. ft.
    » ported box volume: 1.30-3.30 cu. ft.
    Blown subwoofer
    1400 is PEAK power. not to be mistaken with RMS. 1400W in SHORT bursts.
    RMS on them is 500-600W.
    Your amplifier gain may be improperly set. How big is the enclosure and what amplifier are you using. All of these things will play a factor in answering your question. Dont expect a $400 experience from $100 subs.
    Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker Logo
    Top Sony Car Audio & Video Experts
     Francisco Mauricio...
    xxxxxx xxx
    Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
