Mine did the same thing two days ago. No reason to suspect overheat as mine is in the open. Could be the power supply? Mine comes on after sitting for a while.
The RX-V800 switches the various video signal types separately. Since you are feeding S-Video to the TV the composite (yellow) input from your Wii is not going anywhere. If you cant get S-Video output from the Wii then I'd suggest a simple Composite to S-video adaptor plug ($5 say). It worked for me with a Game Cube. Cheers BJ
(I have the RX-V659). Because the Yamaha remote has TWO SEPARATE buttons - power ON and power OFF (standby). This problem can't be fixed. There's a code to choose power ON and another code for power OFF. But one button can't be two buttons. Bad engineering\ design by Yamaha in my opinion
Sounds like they centre has configured your speakers to "none". You need to hook it up to a tV or monitor and go through the menu to "speaker settings" and make sure you select either "sml" or "lrg" for the speaker type. Also ensure on the LFE settings that you select either "swoofr" or "both."
Hey there fontdude, I will begin assuming you are running your a/v cable into your receiver and then out to the TV or Monitor. If this is the case, I suggest you run the video cable direct from DVD or VCR device to Tv/monitor. You can still run the audio through your receiver. The nature of your problem was probably related to video signal strength being weakened as it ran through your receiver. Good Luck! Let me know how it works for you.
