Computers & Internet Logo
Posted on Jan 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have belkin54g wireless router. Now wont connect
Have belkin54g wireless router. Now wont connect to wireless network. Keeps saying wireless awitch not on. But notebook doesnt have a on/off wireless network switch.
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Jan 27, 2010
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3735583
Points
36074
Right under screen there should be a button, or the f8 key I think is another one. You can also search you computer for Wireless Assistant which will turn it on for you.
Hi I have belkin54g wireless router with model no. F5D7234-4v1. I can't configure my router properly I used to configure it by adding new wireless network, new network connection has been created and its...
Hey dude u might have to update the firmware try this link
http://en-us-support.belkin.com/app/answers/detail/a_id/510/~/f5l009-network-usb-hub---firmware-update
Why doesnt my ipod touch connect to my belkin54g network
Go in to setting on your ipod and in setting select connection,then wifi.At there the ipod will ask you for the router password o keys.
If you are having problems connecting either your iPhone ® or your iPod Touch ® to your wireless router please ensure that the routers wireless name (SSID) contains no spaces.
Wrong - My Network
Right - MyNetwork
post or thumbs back!
I have a belkin54g router that has this error message on it. Ive gone to the 192.168.2.1 browser and set up a 64bitWEP. i want to set up a password to connect to my router for security
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Laptop keeps disconecting from nhome network
What is your OS?
What is the signal Stranth.
reinstall the driver.
2answers
Laptop keeps disconecting from belkin54g dsl network (home)
Wireless connections are best when distances are short and there are no brick or thick walls interfering with the signal between the router and your laptop. Try the following test:
Start using the laptop from an open location that is close to the router. Monitor the signal strength as you walk away from the router. Go into other rooms, go upstairs, downstairs, etc, and you will most likely notice differences in signal strength depending on where you are, or how far you move. Of course, you will suffer frequent disconnections when the signal is at its weakest point, no matter what equipment you use, be it new or used.
Try locating the router in a way that your signal strength is strongest, without affecting the other computers. It's a trial and error thing.
One last thing you could do is to go to your wireless adaptor configuration settings and set the Roaming capability to agressive, and set the connectivity to distance, for higher performance.
My psn is timed out????
check the IP configuration of the playstation to make sure it is similar to what you have on yoru PC
My belkin54g router will connect to the internet fine and will browse the web but when i connect to MSN messenger it keeps booting me off of it and when i browse videos on Youtube they only download part...
Try to reset the factory settings on your Belkin54g Router, to make sure also that the Router is working is open the firmware on it. And setting up your internet connection properly. Good luck!
Configure the belkin54g
I had to restore my laptop to the manufature original settings. My belkin54g wireless router is showing up but it won't let me connect. When I go into network connections iw ould see Not connected firewalled. How can i fix this
Would like to connect to my existing belkin54g wireless router
do you have the "default" ones? you may need to reset the router
New laptop, automatically connected to belkin54g, suddenly stopped working. please help!
well maybe you have to connect properly, fist of all i only know the windows vista version but go to .start, connect to, then a list of all available routers will appear, select yours (or the 1 your using). it will then ask you for a password, type it in. click connect. wait for it to load and there you go
i hope that helped
Grand Canyon Tech
Grand Canyon Tech
