After changing the car's oil yesterday, my boyfriend got the oil all over his watch. Is there a way to clean this ourselves, or can it be professionally cleaned?
Hi, if the watch is water proof witch most watches are, if it is it should tell you something on the back like wr 30m or wr 10m if it says this on the back then this is telling you that the watch is water proof up to 10metres or what ever it says if this is the case then you can put it in the sink with only slightly warm soapy water then just rub it over gently with soft cloth whilst under water.
How ever if it says water resistent then this dont mean its water proof this just means its rain proof but not made for going under water unless it says water resistent to 30m then this can be washed in the sink also if it dont say this then you cant put it in the sink you can only wipe over it with a damp cloth to remove as much oil as possible.
But if you can get it clean and its not water proof then the watch is going to have to be taken apart to clean the outer casing that is only if the oil has not got inside the watch.
Oil wont short the watch out put it can cause problems if you have any buttons on the watch so your best bet would be taking it into a watch shop and get it cleaned that way.
Let me know how you get on or if you need further assistance ok
