Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
Need program steps for norlake code# PGD0NL0100, rev. 1.024 or control panel W20449-3.
Anonymous
    New Friend:
Call tech. support
Posted on Jan 28, 2010
Hi my samsung remote is damaged.I have a one for all tv universal remote & have lost the instuctions to program the remote to the tv. I need the instructions program my one for all tv remote to my...
Hello
These are the programming proceedings for a one for all universal remote control.
[1] Turn on a desired device (e.g.,VCR or
DVD player) and, if applicable, insert
media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely
before proceeding.Highlight or write down the
codes and device you wish to program before
starting step 2.
[2] On the remote control,press a device key
once (i.e., TV,PVR,DVD, CBL/SAT,AUD,or VCR).
NOTE: To program control of a cable box or
satellite receiver, press CBL/SAT once.
NOTE: To program control of a CD player or
audio receiver, press AUD once.
NOTE: To program control of a TV/VCR Combo,
press VCR once.After programming, you will be
able to control channel selection, volume, and
VCR functions.
NOTE: To program control of a TV/DVD Player
Combo, press DVD once.After programming,
you will be able to control channel selection,
volume, and DVD functions.
[3] Press and hold SET until the LED (red light)
blinks twice, then release SET.
[4] Use the Manufacturer's Codes to locate the type of device and
brand name and then enter the first fourdigit
code for your device. If performed
correctly, the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps
2 through 4 and enter the same code again.
[5] Aim the remote control at the device and
press POWER once.The device should turn
off. If it does not, repeat steps 2 through 5,
trying each code for your brand until you
find one that works.
NOTE: If the device does not have a POWER
key, press the (Play) key.
[6] Repeat steps 1 through 5 for each device you want to control.
OK.
Jul 03, 2011 | Televison & Video
Do you know the sky+ remote code? So I can operate the volume control on the sky+ remote. I've tried loads already hope you can help.
It would help to know the model number of your LG TV. However, you can try the generic codes for LG which I've listed here:
Rev 8 remote: 1293, 1206, 0206, 0065, 0904
Rev 6 remote: 0065, 0742, 0502, 0672, 0634, 0136,
Rev 4 remote: Same as Rev 6
RC1600/00 remote: codes not available and unlikely to work with your TV
** Your Sky remote version can be found on a sticker inside the battery compartment. **
Try these codes but if they don't work, please post back with your TV model number. It's possible that your remote does not have a code which will work with your TV, in which case, you will need to use the remote supplied with your TV to control volume and power functions. Unfortunately, when a TV is newer than the remote and uses a new flash pattern not programmed into that remote, the remote wont work. However manufacturers often keep the same flash patterns for common functions, so the generic codes might work for you.
I'm informed that a new Sky remote version is due but I've not been able to confirm this yet.
Hope this helps - please post back if you need further assistance.
Regards,
BElectric
Nov 25, 2010 | LG Televison & Video
I have a toshiba regza hd ready flat screen tv. Need to program the sky remote for it but do not know the model number. Can't find it on the tv anywhere or find the manual! Any ideas on how I could find...
The model number should be on a white sticker on the back of the TV. If you can find it, please post back and I will obtain the correct code for your Sky remote.
There are some Generic codes for Toshiba TVs which are:
0536 1536 and 1221 for Rev 8 remotes
0063 0536 and 1121 for Rev 6 remotes
0063 0121 and 0536 for Rev 4 remotes
You can find the Rev number of your Sky remote on a sticker inside the battery compartment. If it just says RC1600/00 then you have the original Sky remote, but you can still try the above codes.
If you need instructions on programming the remote, please post back with both your model number and Sky remote Rev number and I will post the codes and instructions.
Regards,
BElectric
Nov 18, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
We have loads of codes for sky remote control. Do you know which code will enable us to switch the tv off and do the sound control. At present we have to use two controls. TV remote to switch on and...
OK,
This really depends on which brand/model of TV you have and which Sky remote version. The code you need is specific to the brand/model of TV.
The Sky remote version is printed on a sticker inside the battery compartment. The older Sky remotes will have "RC1600/00" on the sticker. Newer versions will also have either "Rev 4", "Rev 6", or "Rev 8" on the sticker.
If you have a new TV and an older Sky remote (i.e. before Rev 8) your remote may not work with your TV and you will need to buy a new Sky remote if you want to operate TV and Sky box with one remote.
Please post back with your Sky remote version number and your TV brand and EXACT model number. I will then be able to provide codes for your remote and programming instructions.
Thanks.
Nov 03, 2010 | Televison & Video
Sky remote code for lg television model no.32pg6000 to programe remote controll on sky remote
Code is 1293 if you're using a Rev 8 remote control. You can check this on the sticker in the battery compartment.
If you are using an older Sky remote Rev 6, Rev 4 or plain old RC1600/00 then it's unlikely to work as these remotes aren't programmed to control your TV. You are welcome to try though ;)
Please post back if you need instructions on programming the remote.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | LG L3200AK Television
I have a Ge refrigerator (model # PDS22MIsacc) it seems to be running alright, but the temperature control panel will not light. we are unable to change tempertures.
you will need to replace the main control board located on the rear panel behind an access panel,this board controls all temps and digital readouts,when the readout goes dark this board is the culprit
Apr 27, 2010 | Nor-Lake Norlake Refrigeration 4' x 6'...
I need a sky remote control code for a UMC LCD Television, Model Ref: S19-4NG. I have a Rev 8 sky remote control. Sky tell me on their web site that I need to upgrade my RC. I have the latest version 8!!!!
Most remotes work the same when programming an item. Try this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 23, 2009 | Televison & Video
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Code for Samsung remote control
With your Sky + remote.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Dec 29, 2007 | Samsung TV Remote Control
How do turn the temp up on a norlake walkin?
They are usually mounted on the front panel of the evaporator or mounted on the wall behind the evaporator.There is a possibility that the temp. control is at the condenser,and the sensing bulb was slipped thru the wall.Look for the bulb at the back of the evaporator and follow the cap tube.
Dec 05, 2007 | Nor-Lake Freezer Norlake Refrigeration 6'...
Refrigerators Logo
137 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Marat Brikov
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
