Question about Apple iPod nano
There is little volume from the headphones but I can hear music coming from the ipod nano itself! How can I adjust it?
    Genius:
  • 1,044 Answers
1 May be the headphone jack has not been inserted properly in the headphone socket. Try removing it and replacing it. OR
2 Check the headphone on any other audio device just to make sure your headphones are OK. OR 3 Press Menu, go to settings, go to volume limit and see that it is fixed to maximum. 4 OR press Menu, go to settings, go to clicker, press the center and fix it to headphones
Posted on Jan 27, 2010
Testimonial: "Thank you. Most helpful."
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Apple Master
  • 1,001 Answers
Universal Bluetooth headset for Apple iPhone 6/5s/5c/5, iPhone 4s/4, Samsung Galaxy S5/S4/S3, PC Laptop, and other bluetooth device; Amazon com Charm sonic Bluetooth Headphones V3 0 Handsfree Stereo Wireless...
Posted on Dec 14, 2016
6ya staff
SOURCE:
My ipod nano has songs but no sounds
Step 1:
Since entering the marketplace and revolutionizing the way people experienced personal audio, Apple's iPod has become the unquestioned leader in MP3 players. Available in several different models and versions including the original iPod, iPhone, iPod Nano and iPod Touch the iPod allows people to listen to any number of songs with just the click of the button. However, as is the case with numerous electronics, certain iPod users encounter issues with their device, particularly sound issues. These issues range from buzzing sounds through the headphones to low volume quality to no sound at all. Fortunately, there are ways to attempt to remedy these sound issues.
Volume and Song Selection Oftentimes, those iPod users listening to heavier music (such as rock or hip-hop) will encounter a buzzing noise when playing their device at maximum or near-maximum volume. Try lowering the volume a bit, as this will most likely remedy your buzzing issues. Also, try playing a different song from a different artist at the same volume to ensure sound quality is optimal across the board. Check the Headphones Before attempting to diagnose an iPod's sound issues, ensure the iPod itself (and not the headphones) are the culprit for these sound issues. Do so by disconnecting headphones from the iPod and playing them on another device, such as another iPod, a PC or laptop. If the quality is still not optimal, the headphones (not the iPod) are likely the reason for low sound quality. Also try connecting an iPod to an iPod listening dock. If the sound quality is optimal, but not so when connected to headphones, that would also indicate headphones as the cause of low sound quality. b> Reset the iPod Sometimes, simply resetting an electronic device such as an iPod, digital cable box or video game system will remedy the solution, as it gives the device a chance to reboot. Try resetting the iPod to remedy whatever sound problem you may be encountering, whether it's no sound or less-than-optimal sound. Not all iPods are reset the same way, so consult the user manual (either paper form or through Apple.com support) to learn how to reset a particular type of iPod. Adjust Sound Settings If sound quality is less than optimal, including too much bass, not enough bass, poor acoustics or any number of other issues, try altering an iPod's system settings to correct the issue. Do so by going to the "Settings" key on the main iPod menu, then going to "EQ." From there, test certain settings to see if they may correct the iPod's issue. EQ settings allow users to set their music to a certain type of genre (in terms of how the music is delivered), as well as lowering bass, increasing bass and altering acoustics. b> Make Sure Headphones Are Fully Connected As simple as it sounds, sometimes the reason iPods have no sound at all is because their headphones become somewhat detached from the device. Such is the case with physical activities such as exercising or doing yard work. If no sound comes through the iPod, make sure the headphones are plugged in all the way to ensure the lack of sound is not a simple oversight. Consult Apple Support Whatever the sound issue, if iPod users have tried everything possible to remedy the problem with no results, they can call Apple support or visit an Apple retailer to help further diagnose the issue. The issue could be a simple fix or might be so severe that purchasing a new iPod is the best course to travel.
Feb 09, 2013 | Apple iPod nano 3rd Generation
Volume wont turn up
Resetting the volume limit on your iPod Nano affects everything you listen to, from music to audio books. You can adjust the volume for each individual item on your Nano using the click wheel, but the highs and lows of the sound will depend on the overall volume limit setting. Volume levels will vary with different ear buds and headphones, and using external devices like docking stations to play your iPod Nano will also cause variation in the volume.
Instruction:
1 Press any button on your iPod Nano's click wheel and turn it on. Press the "menu" button at the top of the click wheel until you reach the iPod menu.
2 Select "Settings" from this menu by scrolling down until "Settings" is highlighted, then click the center button.
Select "Playback" from the menu choices that show up.
4 Select "Volume Limits." You will reach a screen with a speaker icon and dots indicating the level of volume your iPod is currently set on.
5
Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Goodluck
Dec 10, 2011 | Apple iPod nano
Volume wont turn up on my mp3 - volume too low
How to Reset the Volume Limit on the iPod Nano
Instructions
3 Select "Playback" from the menu choices that show up.
5 Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Tips & Warnings
If you set up a combination and forget it, you can reset your iPod Nano and start over again. Resetting will not lose any of your downloads, but you will need to restore or reset many of the settings you initially chose when you first set up your iPod.
Changing the volume limits on your iPod Nano covers everything on your player, but the sound levels for songs, audio books and shows will vary based on how they were recorded.
I transferred music to my mp4, however I cannot hear it when it plays. I know it was transferred correctly, but the music bar moves/plays but no sound is heard. My headphones are new.
Try a different set of headphones, if there is still no sound, check the volume limit on the iPod: http://support.apple.com/kb/TA38403?viewlocale=en_US
if that still does not help try resetting it by pressing the MENU and PLAY buttons simultaneously for a couple of seconds, I hope that did work. But, if it didn't, try doing the diagnostic in it to find out if it is a faulty jack: http://www.wikihow.com/Hack-an-iPod-Nano-3G Hope it is just headphones!
Jan 19, 2011 | Apple iPod nano
My apple iPod nano 5th gen wont play music through the headphones right. It only plays through the internal speaker even with the headphones in. I can hear it through the headphones a little but it is...
take the headphones out play the music full volume then put the headphones in and lower the music all the way down then your volume will be normal and it will only play in through the head phones unless you take headphones out then it will play through speakers
Aug 30, 2010 | Apple Logitech Inc MM50 Portable Speakers...
The speaker on my ipod plays even when my headphones are plugged in. How do i turn off the internal speaker?
un plug ear buds
reset ipod by holding menu and center at the same time for 30 seconds till you see the apple logo - - then reconnect ear bus make sure they make a clicking sound and there is no gap
play a song to test
Apr 05, 2010 | Apple iPod nano
How do I adjust the volume on my iPod Nano with earphones?
Plug the headfones all the way in, force them in. it works, i had the same problem.
Dec 28, 2009 | Apple iPod nano
Sounds like one channel of my music has gone out, I can hear music but no voices or voices that sound like they are in a trashcan, I have already reset to factory conditions and reloaded songs to no avail.
this might be a problem in the headphones (hopefully) or in the iPod itself
is the music coming out of both ears?
no: bend the wire around where it comes out of the iPod. bend it all different directions more than 90 degrees
if not: try other headphones in the the iPod
yes: the problem is probably in the iPod's hardware itself and will ether need to be sent back to apple to be fixed (expensive), or sold.
you could try to fix it yourself, but it could be a number of things so it may be easier to just get a new one
Dec 02, 2009 | Apple iPod nano
Problem with the volume I have to turn the volume to the max to hear music
Check headphone jack is tight, try turning the jack to see if there is a better connection or try different headphones.
Nov 17, 2009 | Apple iPod nano
Using my ipod in my car
try the volume setting on your ipod. it may have to be adjusted. go to settings, volume and see where you are on the slider and adjust to the volume you want. ipods come factory set at a predetermined volume level.
Nov 20, 2007 | Apple iPod nano
Apple iPod nano Logo
129 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
