Question about Sanyo DP42746 42 in. Plasma Television
Power light comes on but no picture. Black screen
Posted by haynesreales on
Anonymous
    New Friend:
  • 3 Answers
If the set appears dead ecept for the power light, unplug the power cord from the back of the set, wait two minutes, then plug it back in and try to turn on the tv. Doing this worked for me.
Posted on Jan 29, 2010
  • Anonymous May 19, 2011
    you need to change the main board the one with tv antenna output rca connection board
1 Related Answer
Anonymous
  • 315 Answers
SOURCE: No picture Screen black
Hi, you need to get your TV kit replaced... Please reply with the model number of your TV if you repairing it by your own.
Posted on Jul 20, 2009
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Spetroniq 42"lcd screens black no picture no
Sounds like maybe power supply, but I would check with flashlight 2 in from screen when the green light comes on to see if you have a picture, if so then you have a bad inverter board, if not then power supply problems. You can look for bad or bulged caps in PS
Jan 06, 2011 | Spectroniq PLTV-42HW68 42 in. LCD TV
Will not come on, the lights come on but the screen is still black
This sounds like you have bad capacitors on the power supply board. Look for bulging capacitors. Any weak capacitors will have a bulge at the top. If you know how flourescent lighting works with a ballast, tv's work the same way to power up the backlights but use capacitors. The backlights when lit allows you to see the picture. If they are not charging up fully you get a black screen or a very dim screen which looks black under normal lighting conditions. Sometimes you can turn off all lights and maybe see a faint picture.
Mar 04, 2010 | Vizio VW32L 32 in. LCD HDTV
Jul 20, 2009 | Protron Televison & Video
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
Sanyo DP42746 42 in. Plasma Television Logo
739 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
