Question about Gateway FPD1975W 19" LCD Monitor
My gateway FPD1975W 19 INCH LCD MONITOR DOEN'T TURN ON, THE SCREEN IS BLACK
Posted by sabaax123 on
Anonymous
(thank you budmrtn) my monitor shut off..i went online looking for solutions gate way fpd1975w..i looked hard for about 2 hours..i found a common problem was with the power supply..(budmrtn) hit it on the head..i am not an electronic expert at all..i have a soldering gun..thats is..no testers..so i took the monitor apart and found the power supply was a seperate board..i took it out and looked at it and said hmm. do i throw the 180.00 monitor out or do i take a chance..i took the chance..i went to radio shack and bought 10 capacitors like (budmrtn) said i replaced them..if it did not work i was out 10 buck and i was going to throw it away..but well and behold..i replaced the capacitors..just the big ones not the round blue ones..and wala..new monitor..it worked..crazy i no..but it worked..and i have a 19 inch lcd that works and i was going to throw it away..if you need to know what i replaced email me and ill let you know..
Posted on Feb 01, 2010
Anonymous
    New Friend:
I got my Gateway 1975w, but without any software, Can anyone help me to find EZtune and driver for LCD 1975w
Posted on Jan 29, 2010
Bud Martin
  • 11,361 Answers
First place to check will be the power supply, look for bad caps with bulging tops or bottom seall first and report back what you find then we can guide you futher, see what bad caps look like here:
Posted on Jan 27, 2010
2 Related Answers
Anonymous
SOURCE: power supply for Gateway FPD1975W 19 inch LCD
try replacing the crystal on the power supply 8 out of 10 times it is the problem
Posted on May 18, 2008
Anonymous
  • 1605 Answers
SOURCE: Gateway FPD1975W black 19 inch LCD
most likely is the power supply in the monitor.
gateway LCD has a building power supply in the monitor. it supplies 38W to the lamp.
since there is no display, it tells me that there is no power to the monitor.
if try another monitor and it works fine. then the problem is the monitor. (dispaly lamp is good for 17 Years- according to the tech spec.) but the power supply is pushing too much power.
other vendors max power is apporximately 30W.
make sure there is nothing behind the monitor and has good air flow. Since there is no fan in the unit. it need to vent the hot air natually.
Posted on Oct 20, 2008
FPD1975W TFT LCD monitor my monitor blinks a blue power light and flsahis a white screen but it does not turn on ?
A flashing power light indicates a failure of the power supply, this will also cause the white screen. Here is a link to a page showing what parts need to be replaced to repair the power supply board and get your monitor back running again.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps, if so please rate my solution,
BuddyMc
Fuzzy screen on Gateway FPD1975W TFT LCD Monitor
With the pixels acting up and the monitor having the same problem on any computer that its connected to. The screen itself is bad and since there are no replacement screens for that monitor, you would have to buy a new monitor or get it replaced if its under warranty.
FPD1975W (Black) 19 inch LCD Monitor: power button flashes but not coming on...
Open the cabinet and remove CMOS battery and harddisk connection from motherboard.
And reboot the system. It will give the msg no boot device found. Now place again the cmos and harddisk and reboot
1helpful
Screen turns black when tring to play video games
update the display adapter and check with the requirements for the game
if required upgrade the video card
Connection?
check the videocard. remove it and place it again if no improvement try to connect monitor to another system. If no color, replace monitor.
Where can i find a power cord for my fpd1975w 19 inch monitor?
bring your power cord set and go to electronic or computer sales shop
19 inch tft lcd monitor blurry
go to control panel click on display icon and then go to setting tab and there you will find screen resolution settings
2answers
Power supply for Gateway FPD1975W 19 inch LCD
Gateway FPD1975W 19" LCD Monitor Logo
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Jessie Goss
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
