Plumbing Logo
Question about Plumbing
How do i get the collars of a ''y'' over the cut ends of the existing sewer pipe where I need to install the ''y''? I'll dig down 24'' to the existing sewer pipe but I don't think it will move or flex enough for me to work the collars of the ''y'' over the ends after I cut it. Is there a non-collared ''y'' and slip joints? Can I dig up a couple feet of the pipe in each direction and get it to move enough to slip to collars over the ends? What do plumbers do when they add a clean-out plug to an existing buried sewer pipe? Thanks!
mikenearman
    New Friend:
  • 127 Answers
Glue in a 12" piece of pipe into each end of the pipe (not the vertical).....take that total measurement and cut the existing line enough to allow it to go inbetween.......get two "no hub" or "hubless couplers......glue everything up......slide the couplers on the existing pipe....position the wye/pipe.....slide couplers over. That will have to be done in a very fast manner.
The other option is getting rubber couplers as you don't have to worry about the glue going off.
Hope this helps and good luck.
Mike
Posted on Jan 28, 2010
Testimonial: "Not just one, but TWO possible solutions. Thanks!"
PLACE A SHARK BITEHOW DO I USE SHARK BITES
Cut the pipe. Deburr. Push on the new sharkbite fitting. If you have to remove see below. A disconnect clip is a small orange c shaped clip sized for the size of the pipe. Sold were you bought the fitting.
How To Remove a SharkBite Fitting
  1. Place SharkBite Disconnect Clip around tube with the non-branded face against the SharkBite release collar.
  2. Push the SharkBite Disconnect Clip against the release collar and pull the tube with a twisting action to release the tube.
- See more at: http://www.sharkbiteplumbing.com/sharkbite-u710-disconnect-clips#sthash.VSbPmbf2.dpuf
Oct 27, 2014 • Plumbing
Sewer line
hard work here I am afraid. At the wet spot is a good spot to start but be prepared as water travels before it becomes a noticeable wet spot. Use a post hole shovel and dig slowly until you get to the pipe then dig either side . You may have to flush several times to get the crack located as there should be little or no water in the line.
3helpful
3answers
Sewer waste pipe replacement
plastic or croc? earthen ware? whats the material?
3helpful
3answers
I had my drain snaked out and a camera put in to see if there was a problem, I was told the pipe must be cracked although he said he could not get the camera all the way down. After snaking out roots and...
Did you see them pull out the roots? The camera has become a sale tool that makes a great deal of money. If I were you I would sit on the job and not do anything right now.
If and when it stops up again you need to watch them work. Check the cable they are going to use and make sure there are not roots on the cable from an other job. Then watch them run the cable if they dont pull back roots. You dont have roots.
If they do pull back roots then you must chose to kive with the cost of snaking out the line lets say every year or 6 months. If that the case you need to ask your self how long am I going to stay here,
It might be cheaper to clean the drain out for 200.00 than to spent 10.000.00 for a new line.
I am not saying that 10.000.00 dollars is your number depending what state you live in will control the cost.
But a rule of thumb would be anywhere from 100.00 per foot to 200.00 per foot. Get 3 prices you can do that over the phone. Just ask the guy who you are talking to now and ask him or her " how long of a run is it?" so then you have your footage the ask him his price per foot.
Best of luck Dont get taken and if you replace the line tell them you want a permit and a copy of it and the inspection card.
Best of luck RJ
Sep 08, 2011 • Plumbing
I have a Casio (593 F91W) and cannot get the pins out to change band. Jeweler cannot get the pins out. What is the secret?
It's likely that your band pins are thin and do not have collars that can easily be grabbed by most band removal/installation tools. If you are already changing the band, the best thing to do would be to cut off the band so that the pins are clearly visible, then use a set of nipping pliers to cut the band pins in the middle. At best, you'll cut them in half; at worst, you'll bend the pins into a "V" that will pull at least one end out of their holes. Obviously, you'll need fresh pins with your new watch band.
Efforts to dig the pins out of their holes can easily damage the holes themselves, making the watch useless.
How to replace the trap for kitchen sink..there is a leak in the kitchen trap
open to drain pipes. remove the collars that hold trap on, sometimes you may need pliers or a pipe wrench to remove.install is reverse of removal the trap is there to contain the gases in drain pipe. if no trap. you will smell sewer water all the time. 1-1/4 for bathroom drains and 1-1/2 for kitchen sink drain.
Digging hole and have cut the top of the rainwater tank pipe about 500mm in the ground, pipe is pvc and 90mm round
The tank is 19&11/16 deep. the pipe is 3in PVC, SCH40. I will need a reciprocating saw w/8in blade, a peice of 3 in pipe 4 ft long and 2-3 in of SCH 40 slip couplings or 2-3 in compression couplings. ,Pipe joint compound, Glue and primer if using the slip coupling If your using the compression couplings,2-24 in pipe wrenches and a spade.Dig the line up exsposing the broken pipe plus about 12in to 18in more pipe on each end..Cut out the broken porsion plus 8 to 12 inoneach end leaving 6 in or more pipe on each end to tigh on to,Measure the distance of pipeyou have cut out .Cut your replacment pipe 1in shorter than the peice you cut out Slide your comp, couplings all the way onto the replacment pipe .Manuver pipe into place .Slide the comp, couplings onto the exsisting pipe half way,splitting the distance in the middle of the couplings.Put pipe joint compound on the threds and a little on the bevel of the rubber union gasket Tighten the couplings evenly.Check your grade it needs 1/8 in p, ft If its all right then backfill to the top of the pipe and tamp the earth making sure the pipe is commpleatly secure then back fill the rest of the ditch in 6 in increments tamping between layers.
Nov 03, 2009 • Plumbing
1helpful
2answers
Installing a Washer in basement
The top of the drain pipe that the washing machine drains in to should be about 3 feet off the ground. If the sewer pipe is higher than that you can either get a longer hose, or drain it into a sump with a sump pump that pumps it into the sewer pipe. If you don't have a sump, first try the longer hose and make sure it drains to a point higher than the sewer pipe (that would be the easiest) or cut a hole in your floor and put in a sump and sump pump (the most difficult).
Top Plumbing Experts
john h
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
