Question about Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint WF860, one of the blue/green bars on the inside of the drum has broken and come off. Do you this part? Thanks. Ruth
Posted by ruthpscott on
Barry Coates
  • Hotpoint Master
  • 3,463 Answers
Hi.
You need to order the part from Hotpoint direct, or through one of the local dealers who sell spare parts for washers.
The hotpoint address is>>>>
WWW.HOTPOINTSERVICE.CO.UK
Click on SPARES
.Please rate my solution.
Thankyou
Posted on Jan 27, 2010
How can i replace the drum lifters in my Bush A147CR6B washing machine?
They are hard to replace. Be careful and wear a pair of goggles. You must be strong and careful when doing this. A pair of mechanical pliers and a long slender strong flat edge screwdriver will do the trick.
Jan 12, 2014 | Hotpoint Ultima WF860 Front Load Washer
Can I replace the rubber drum seal on my Hotpoint WF860 myself, if so where can I get one?
ebay best place very easy to change if you remove the spring on the seal on the front of the machine you can get to the clip to take of the inside you can take off the lid to get to it from the top thankyou
Jan 21, 2011 | Hotpoint Ultima WF860 Front Load Washer
Drum is not spinning, what could be wrong?
motor brushes worn, motor faulty, broken wires or faulty module. unplug b4 checking.
Apr 05, 2010 | Hotpoint Ultima WF860 Front Load Washer
Where is the filter on a hoitpoint ultima wf860
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The filter is under the rear of the machine inside the sump hose. Remove the lower rear inspection panel and tilt the machine forward, keep it tilted by placing a tin of peas or something under it at the rear. Now put a shallow bowl or dish under the sump to catch any water that may still be it the drum and remove the retaining clip. Pull the hose free from the tub and the filter is inside. (Work safe and remove the power plug from the wall before commencing any repair) For more tips on repairs use this link selfix-uk
Mar 11, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF860 pump obstruction. How do I get to pump?
Remove lower rear panel of washer.
Locate and remove the large black hose fastened to the bottom of the drum.
Remove and clean the plastic filter inside the hose.
Remove the hose onto the pump, and check for blockage or obstruction here and in the pump.
Thisn should the problem.
Good luck.
Dec 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Water will not empty out drum
You need to check the pump filter, if it is not at the lower right front of washer, then remove lower rear cover of washer, remove large black hose fastened to bottom of drum, and remove and clean plastic filter inside hose.
Thanks.
Nov 01, 2009 | Hotpoint Ultima WF860 Front Load Washer
Where is the filter on a hotpoint wf860 washer
The filter is underneath the drum, inside the rubber that exits the drum down to the pump
Aug 25, 2009 | Hotpoint Ultima WF865 Front Load Washer
How do I replace Drum paddle on Hotpoint WF860 washing machine
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Thanks.
Mar 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Drum Paddle broken Hotpoint Aquarius
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wd420 leaking
they are called paddles ,they just slide and lift.can you rotate the drum with your hand??
Nov 26, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
67 people viewed this question
Top Hotpoint Washing Machines Experts
James Hehling
James Hehling
Level 1 Expert
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
