Question about Nintendo DS Lite Console
Orange light for a second then nothing
I replaced bottom and touch screen on ds lite,now I only get the orange light for split second when I plug the adapter in and nothing.Battery is full charged and adapter is fine,checked F1 & F2 fuses which are ok.Also ensured that pad was placed on bottom screen to prevent shorting,any help please!
Anonymous
    New Friend:
  • 57 Answers
Possibly a bad charger? Try getting a new one.
Posted on Jan 28, 2010
My ds lite just switched off and it was charged
Hi, so if you try switching on the ds lite, nothing at all happens ??
Does the green light flash even if it is for like a split second.If it does then it is more likely top be a blown fuse. If 1 of your screens flicker also, this could be your problem as the ds will not start up with a broken screen. Please advise
Jul 31, 2012 | Nintendo DS Lite Console
The orange light was on, charged it up and everything working fine then just went off. When turning it back on again the green light goes on, the screen flashes for a split second then nothing? It is...
you probably have a dead battery and it will need to be replaced. you can buy one on eBay and do it yourself or you can bring it to a repair store to get it fixed
Mar 09, 2011 | Nintendo DS Lite Console
Bottom internal touch screen cracked on ds lite-how do we get it repaired
Unless you are comfortable of taking it apart yourself and ordering the part online.
I'd suggest going here.
http://www.nintendo.com/consumer/repair/dslite_repair_home.jsp
Mar 03, 2011 | Nintendo DS Lite Console
I replaced the bottom screen and touch screen on my DS lite and reassembled without and issue, making sure all copper colored connections were snug and snapped, black and white cables are reattached,...
i did the same thing and had similar problems i solved it by putting electrical tape over the back of the new screen (which was just baremetal the orginal screen had some plastic on it i think) the bare metal screen must have been shorting it out give it a try
Nov 23, 2010 | Nintendo DS Lite Console
Have just replaced both bottom screens a little fiddly but no problem but now ds will not start up, put the charger in and the orange charge light apears for a split second then goes off and console will...
Hello!
If you replaced the lower LCD PLEASE check to see if you put a pad on the bottom of the lower lcd... If the metal is touching the board then your LCD and causing the board to shutoff! and not power on.
That's the main reason your DS wont power on if you changed those things.
Also!
Your F1 or F2 fuse could have died out as well.
Dec 29, 2009 | Nintendo DS Lite Console
My ds lite wont power on how can i fix it?
One of you're screens is broken or the F2 fuse has blown.
Check youtube for a video on "how to check my DS lite F2 fuses" there are several available that give step by step guidance on how to do this.
Having checked these (and replaced blown ones) and you're screens are still not working then it is a screen that has blown.
If the bottom screen flashes for a split second when you turn it on then it is you're TOP screen that has blown and needs to be replaced. If it doen't flash then it is you're bottom screen that is broken and needs to be replaced.
Sep 10, 2009 | Nintendo DS Lite Console
Nintendo DS won't power-up
It sounds like a faulty battery. As it is under 1 year old, it is still under warranty. Return it to the origional place of purcase, who will either fix or replace it.
Aug 19, 2009 | Nintendo DS Lite Console
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
Replaced Bottom screen bypassed fuses still problems
the backlight or fuses are dead. Do not bypass fuses or you'll kill your system.
Jan 23, 2008 | Nintendo DS Lite Console
Nintendo ds lite repair
call the company and tell them TRY IT
Aug 13, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
171 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Anon
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
