Question about Fisher and Paykel Dishwashers
Dishwasher is beeping. Also has an F1 with a
Dishwasher is beeping. Also has an F1 with a spanner sign. It has done this previously and I switched it off overnight and it started up with no problem in the morning. This time it just keeps beeping. What do you suggest. thanks
Anonymous
    New Friend:
Paano maviverify ung friendster ko e ayaw mabuksan
Posted on Jan 27, 2010
Testimonial: "Solution was in a foreign language wasn't able to understand."
Washer keeps blinking with a spanner and F1 function
F1 is a flood error. Below is a link to a video that you can download that shows you how to repair your dishwasher.
Solution
Good Luck
6helpful
2answers
F1 Error code
Hello, here is link to F&P repair video. This video explains how to repair a F1 error code and replace the rotor
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
9helpful
2answers
Disherwasher double drawer has a F1 fault have turned off power and back on again and has stopped beeping but faultF1 and spanner logo still showing ,help please
I am assuming the F1 fault is showing on both the drawers.
This is normally due to flood switch at base of dishwasher housing getting set.
This is due to water leakage from the drawers into the base. To clear it you need to turn power off. Take out the bottom drawer and dry the base of housing with towels and hair dryer. The flood switch is mounted on power board at the base.
Put drawer back and turn the power on. The drawer removal is done by taking out 2 plastic plugs one on each side of drawer and taking front cover off. Then pull drawer out and unclamp from rails. Pull out carefully without damaging houses and wiring a the back. Put back in reverse.
1helpful
The unit flashes F1 with a spanner sign showing on both drawers
Refer your problem with fisher and paykel DD603 dishwasher. Please clarify how are you able to assess the motor is driving in top gear. Which lights are flashing?
Is this problem in both drawers or just one?
3helpful
Our F & P dishdrawer keeps coming up with f1 and a picture of a spanner have tried turning the machine of at the switch for 24hr but is still doing it
Water has collected at the base of the dishwasher under the drawer.
This triggers a flood switch and causes the F1 error.
Turn the mains power off and extend the drawer out as much as possible. Take towels to dry the base from inside. Also use hair dryer ot dry out the flood switch mounted at the base.
Turn the power on and see if there is any difference. The cause of water collection could be many. Foam in detergent or kink in drain hose or drawer door gasket leaking etc.
Lights come on with f1 spanner sign flashing and bleeping
There is a leak causing the bottom housing wet so the floor sensor triggers. Dry out the bottom housing F1 will be disappear. However if the leak is not fix, the sam problem will happen again. The leak is from improperly being sealed between the top lid down against the top edge of the tube during operating.
1helpful
My dishwasher is showing signs of a spanner
I am slightly unsure if your double drawer dishwasher is the prefinished model (self standing with LCD display) or the integrated model with no LCD display.
The spanner symbol on the top drawer is telling you that a fault code is actuated. But I am not sure where this symbol is on your unit if it is built -in (integrated model).
You will have to check which red light (from the left) is coming on.
I assume there are 5 lights on the inside of drawer.
With the bottom drawer - again you will have to check which light from the left comes on sometimes as you mentioned.
If you have a user manual you should be able to tell what Fault code it is - something like F1 or F2 etc. Is it continuously beeping when the red light is on? How do you turn the beeps off?
The scrubbing bush symbol on bottom drawer may not be a problem. It appears the drawer is programmed to a particular option. But I am not sure where this symbol is showing if you do not have an LCD display panel. You can reset the option - possibly auto lock or auto power or dish cleaned (depending on your model) if you follow the user manual.
happy to take you through a possible cause of the problem if you post answers to my questions above.
HI my fiser and paykel dishwasher is flashing f1 and is showing a spanner whay does this mean
The F1 error means a flood switch has been activated in the drawer. The spanner means you need to call a technician.
The possible causes are that the solenoid that controls the water inlet does not shut off or the sensor that detects the water level is not working. Also it is possible the water pressure is not optimum for the setting on your unit.
2helpful
We have the Q 2 drawer dishwasher stopped working.
the f1 is the flood sensor....a leak has accured....either a dish to larger or lid motor has failed. will need to remove bottom drawer and soak up water and then let air dry for a day or two....turn off the breaker this will keep it from beeping and running the pumps....after drying unit will run, but need to watch the dishes you put in drawers.
5helpful
2answers
F1 code on Fisher and Paykel dishdrawer
It would seem to be in an endless loop (firmware glitch). Initially, pls try:
  • unplug from the mains or switch off the breakers for a couple of minutes;
  • plug back in/switch on the breakers say after 20 minutes;
  • press POWER to turn drawer on;
  • Press and hold (at the same time) both the POWER and ECO buttons for a few seconds;
  • a five minute demonstration wash cycle will come on;
  • press POWER again to put unit on standby, all the LCD segments will start flashing (and light up);
  • press and hold START/PAUSE for a few seconds to hear confirmation beep/tune.
Alternately, should you have the two-drawer, open any drawer and look at the wash intensity/economy buttons. Now press them, one at a time, alternating between the two, at even timing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Dishwashers Logo
Top Fisher and Paykel Dishwashers Experts
Michael Thomas
Michael Thomas
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
