Question about Toshiba 72HM195 72" HDTV
My 72hm195 color fades then picture jumps now i
My 72hm195 color fades then picture jumps now i have sound and no picture and tv clicks off and on. before picture went heard pop sound.
Posted by misshotnfab on
Chi Chu
  • Toshiba Master
  • 8,457 Answers
Ur LCD inverter board it dead,U replaced this board to get picture back.It usally aa long board.
Posted on Jan 27, 2010
Julio Hernandez
  • 616 Answers
I know its an old thread, but mr. chichu is not even trying to read stuff correctly, the 72hm195 is a DLP tv, this particular one uses a lamp, which has blown, there are no inverters in this tv, sheeshshhshshs !!!!!!!!!!!!!!!!!!!!!!
Posted on Sep 28, 2011
The color on my Advent TV fades in and out of the picture, and goes to black and white Why
The problem is in the picture tube board circuit. Sometimes the CRT socket doesnt connect well to the CRT pins. Or maybe there have bad solders from RGB transistors. check those transistors, Also the bad thermistor discolored the entire tv screen.
Sep 29, 2014 | Televison & Video
Buzz sound from Toshiba model 72HM195
Mine is doing the same thing. I think its the cooling fan. The bearing is probably gone.
Nov 22, 2012 | Toshiba 72HM195 72-Inch Diagonal...
Television is a Tosiba DLP 72HM195
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
Feb 22, 2012 | Toshiba 72HM195 72" HDTV
Faded and bright
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Philips 60PP9352 60" Rear Projection...
My Toshiba 72HM195 72 in. HDTV powers on but no picture comes up, but it has sound and wants to turn back on after turning power off
Won't shut off ah, sounds like a Toyota, you can't stop those either, if you are getting flashing green or red lights your lamp is burnt out, time to replace.
May 01, 2010 | Toshiba 72HM195 72" HDTV
My hitachi ultrascan hd tvs color is fading ?
Sounds lamp in TV getting weaker and soon it will be replaced.
When dlp tv start showing darker picture then its time for new lamp to get back vivid picture.
Dec 17, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Picture on my Bose Lifestyle 35 is jumping around
Hi
Replied you on premium post as well.
Please change TV color system to AUTO to see jumping free picture.
If Bose is either on PAL or NTSC color system, TV will show correct picture and color automatically.
Feb 08, 2009 | Bose Lifestyle 35 System
Sylvania Model 6420FF Television - How Do you Adjust Color?
Hit menu on your remote - click on picture - scroll to color
If you need a copy of your owners manual please click here
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Oct 21, 2007 | Televison & Video
Tv shuts off
When you let it sit for approx. 15 minutes it will come back on and usually stay on. I've also noticed that the color will fade in and out at times. during 15 mts of your sitting do you get sound & less brightness then problem in video or luminance section. if picture is dim & color will fade in and out at times then possibility of crt is getting less voltage on g2. if set is old then there is a possibility of crt getting weak. but if the above things are not there then problem in power supply. good luck
Sep 22, 2007 | Mitsubishi VS-55707 TV
Toshiba 72HM195 72" HDTV Logo
406 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
